truckone176
- Messages
- 25
- Reaction score
- 1
Hello, I have a 2275 RCW with the Yamaha 250 SHO. I noticed this past weekend the the motor is mounted on the upper most hole. I was wondering where everyone else has their motor mounted?
As soon as I get my originalThanks, like to hear about the difference.
I would like to suggest when trying different things (height, prop etc.), you should always do one thing at a time. That way if something changes (for better or worse), you know what it was that made the change.
For sure solid advice. I've got no trailer and boat was going to shop for annual service.....thus I was lazy and had them do both Knowing I can easily change the prop if I didn't like it. Was running a 16 pitch and could bounce it off the rev limiter in lowest setting so figured a 17 in the next hole would be right......wrong. Now back to the 16 to compare apples to oranges re mounting height. Stayed tunedI would like to suggest when trying different things (height, prop etc.), you should always do one thing at a time. That way if something changes (for better or worse), you know what it was that made the change.
Are the sho motors 20” or 25” shaft?
