jabo
Has anyone had an issue with a brand new Yamaha motor stalling on a restart? To be clearer, I have a 2016 Yamaha 90 4 stroke fuel injected. The initial start-up is ok. After swimming or whatever for a little while when I go to start the motor again it will act like it is going to run but immediately dies. The next crank it runs like it should. I have talked on the phone to my dealer and all he could come up with is possibly air in the fuel line. I'm hesitant on taking it in right now because it always starts and runs fine on the second try and I don't want to waste summer boat time. Thought I would run it by you all to see if anyone else has encountered this before and what solved the problem. If I can't figure it out, I guess I will make the 1 1/2 hr drive to the dealer after the weather cools off.
