Welcome to Club Bennington
Login Register
Yamaha F200 (not digital)
Discussion in 'Technical Stuff' started by Jacob Dixon, Nov 11, 2016.
  1. Jacob Dixon
    Jacob Dixon Active Member
    38
    3
    I just purchased a new 2017 Bennington SSRX with a Yamaha F200 (which i'm told isn't digital.. the one I got). I want to connect it to my Lowrance HDS-7. I'm getting some mixed data online about what exactly is needed so I had a couple questions:
    • Do I need a single cable to go from the engine to the NMEA 2000 port on my Lowrance HDS-7?
    • Do I have to convert it to digital first and then go to the Lowrance?
    Just wanted some opinions if anyone has done this with the F-series engines
  2. SEMPERFI8387
    SEMPERFI8387 Moderator
    7,785
    2,141
    York, Pa
  3. Jacob Dixon
    38
    3
    It is a little confusing to me too. I *THINK* I just need the Yamaha-to-NMEA adapter and the NMEA Starter kit to create the network. So the Yamaha-to-NMEA adapter goes into the NMEA network and so does the Lowrance.
  4. SEMPERFI8387
    7,785
    2,141
    York, Pa
    I believe the starter kit is to add more than one thing though. If only using the Lowrance, I think you just need the Yamaha cable. I believe the network just allows you to use the t's for multiple displays.
  5. Jacob Dixon
    38
    3
    I wasn't 100% because the documentation says the network is required. I really wish these dealers knew more about this stuff!
  6. Jacob Dixon
    38
    3
    I ended up getting it wired but don't get how many gallons are left in the fuel tank.
    Here is all I needed:
    That was it! Interface cable connects directly to a plug in the engine. To get digital trim there was two cables taped with yellow cable (one had a pink cable). I just untapped them, took the caps off and connected them together.
Share This Page
