Yamaha RPM
Larry
Delaware
I have a Yamaha 115 4 stroke on a 2012 2275 gcw. Purchased in 2013, motor ran at 5600 rpm WOT since purchased. The last few weeks motor runs normal for about 5 minutes then rpms start jumping up to 6800 but motor sounds no different and speed does not change. These measurements are on the factory installed tach. Anyone have any ideas what is causing this?
Lay Lake
Alabama
Could be a faulty tach Guage or a wiring issue. A loose wire can cause crazy things to happen. I would check the wires on the back of the tach to make sure they aren't loose or corroded.
Bill N
There's a dial on the back side of your tach.
Note which position it's in, then rotate it back & forth full cycle leaving it in it's original location (thus freshening up the electrical connections).
Probably not the issue, but very quick, easy and free.
sunedog
If the motor doesn't sound different and the speed doesn't change, I am ruling out prop / cavitation / ventilation, etc. Sounds like a gauge problem or signal problem.
I'm no expert, but Google tells me modern tach's get their signal from the ECU and the ECU gets it from either a crank position sensor or a camshaft speed sensor.
Food for thought.
Larry
Delaware
Thanks
Larry
Delaware
Food for thought.
Thanks
thanks
JohnL
Delaware
Although I have a different Yamaha motor, the tach does the same thing. It is a tach problem. I connected the engine information to my Garmin so I can watch the RPM’s and the reading on the Garmin stayed steady as the tach went up and fell back down. It’s to the point I don’t even bother with the instrument tach, I just use the Garmin.
Larry
Delaware
Thanks
basshawk84
East Texas
My tach acts up like that now and again also.
