crookedlaker
- Messages
- 12
- Reaction score
- 0
New member, first post
Well starting to look at new boats, probably about a year off but trying to decide what to buy
My local dealer sells Bennington and Harris so it will probably be one of those.
I have a 20' two tube Harris with a 90 but I need more speed
My ideal boat would be a 22' tritoon with a 150
The dilemma i have is that my trailer is a center lift and my covered boat lift is also a center lift type so i would have to
buy a new lift and trailer $$$. One other problem is to get from my house i have to go under a low bridge, in the spring time with the
high water i have to remove the windshield, head rest and drop the Bimini off the short legs and sometimes only clear by a couple of inches. This only last 3-4 weeks in the spring but with the higher ride height of a tritoon i may not able to go out on the lake.
I am thinking that a 22' two tube boat with lifting strakes and a 150 may work. we do not do much in water sports maybe ski or pull a tube a couple time a year if we have guests. mostly cruising and anchored at the sandbar.
how does the lifting strakes affect the boat compared to a regular pontoon, if i can get into the mid to upper 30's i would be happy.
My neighbor has a 22' Harris two tube boat with a 150 (no strakes) and he runs about 35 mph.
I would be OK with buying new lift and trailer but the bridge is the big concern. My budget for the boat is approx 35,000.00
upgrading the lifts and trailer will cost an additional $5000.00 even after selling my old ones. I could probably save almost 10,000 by going with the two tube boat.
If anyone has a two tube boat with strakes your thoughts would be welcome. also i did see the elliptical two toon option, how does that boat handle and how much higher does it
float compared to two toon pontoon I realize that this configuration will require a new lift and trailer.
any thoughts and comments are welcome
Mike
Mike
