Bimini not staying in the rubber slot along arch
Matthewstm
I have 2018 23RSB pontoon with the arch. When the Bimini is in the up position it pulls the Bimini out of the rubber gasket along the arch. Has anyone experienced this? If yes, how do I fix this?
If I am understanding the problem correctly; is your Bimini stretched so tight it is pulling it out? If so might need to make some adjustments on the frame
I’m unclear as to ‘what’ can be adjusted. Any ideas?
