Bimini Top Latch Connector Bracket
BradLee
This is for a 2016 22 SSRX. There are four, 2 front and 2 back corners and are fitted inside the square framing. Used to support the Bimini top by snapping into a bracket mounted on the railing. Made from injected molded plastic. They are not locking into place, keep slipping out and not supporting the top. Don’t look broken or worn, just won’t stay in place. Anyone familiar with this problem?
ILLINOIS AVE
Green Lake Wisconsin
How about adjusting the Bimini with the knobs on the front bracket? Maybe to much tension when Bimini is up ? I had to adjust mine once ! Just a thought.
BradLee
Not sure how I would adjust. The pieces that are slipping are molded plastic. They look like a pipe wrench without the teeth.
Remediation
You are not adjusting the connector. You loosen the turnwheel on the straight tubing extend the tubing like a tent pole and tighten the bimini, that will put more pressure on the connectors.
Remediation
it's harder to explain than to do. You will figure it out. our tubes are tight enough that we have to pull the front of the bimini down to get the connectors in the front mounts. then most of the pressure is up on the pin.
Justin M
CT
Sometimes you need to give them a good whack to get them fully seated.
Potomacbassin’
Annandale, VA
I adjusted my bimini arms in many different positions and even had the dealer give it a try. Unfortunately for whatever reason mine did not have that latching ability beyond a certain MPH.
The bimini was replaced due to some warranty issues, and the new one doesn't latch well either, so I assume it's the conditions that I run exceeds the design. It's just soft plastic so I don't expect it to hold on when I bouncing in 2' seas at 35mph.
