Eagle 1
- Messages
- 99
- Reaction score
- 3
How many dollars per mile do you spend at full speed (WOT), at 3500 RPM (Cruising Speed) and at 2500 RPM (Slow Speed)?
Have you ever wondered what the fuel costs are to run your boat engine?
http://www.yamahaoutboards.com/owner-resources/performance-bulletins
Based upon the Yamaha Performance Bulletin measurements from the above website, and using an estimate of $5.00 per gallon as an average cost of gasoline, I have estimated what the fuel costs should be for full speed (at WOT), cruising speed (at 3500 RPM), and a comfortable slow speed (at 2500 RPM) for Yamaha 250 HP engines, Yamaha 200 HP engines, and Yamaha 150 HP engine respectively. (The 250 HP and the 200 HP Yamaha engines were each mounted on separate 2375 GCWs, while the 150 HP engine was mounted on a 2275 RLi.)
If my calculations are correct:
The Yamaha 250 HP (on a 2375 GCW) will cost you about $107.50 per hour at a full speed of 44.6 MPH (at 6000 RPM using 21.5 GPH); and will cost you about $29 per hour at a 3500 MPH (a cruising speed of 20.8 MPH using 5.8 GPH); and will cost you only $19.50 per hour at a 2500 RPM (a slow comfortable speed of 12 MPH using only 3.9 GPH).
The Yamaha 200 HP (on a 2375 GCW) will cost you about $92 per hour at a full speed of 40.0 MPH (at 5800 RPM using 18.4 GPH); and will cost you about $26 per hour at a cruising speed of 21.5 MPH (at 3500 RPM using 5.2 GPH); and will cost you only $15.50 per hour at 2500 RPM (a comfortable a slow speed of 11.7 MPH using only 3.1 GPH).
The Yamaha 150 HP (on a 2275 RLi) will cost you $78 per hour at a full speed of 37.6 MPH (at 5700 RPM using 15.6 GPH); and will cost you $25.50 per hour at a cruising speed of 20.8 MPH (at 3500 RPM using 5.1 GPH); and will cost you only $13.50 per hour at 2500 RPM (a slow speed of 11.3 MPH using only 2.7 GPH).
Since my wife and I are 62 and 59 respectively we will be content to run our boat slowly at about 10 MPH just to enjoy the beauty of nature and to see the sights. I estimate this will cost me about $12.50 per hour at 10 MPH at about 2300 RPM using about 2.5 GPH at $5 per gallon.
For me, next year I will have a 2014 year Bennington 2375 GCW model with a 150 HP engine.
At WOT I expect to go about 37 MPH at 5800 RPM. According to the Yamaha Performance Bulletin (Y.P.B.) I will probably use up about 15.7 GPH at WOT. Multiplying this same 15.7 GPH times $5 per gallon means it will cost me about $78 dollars per hour to run my boat at full speed for a whole hour; and this same $78 per hour DIVIDED BY 37 MPH means it will cost me about $2.10 dollars per mile for every mile I run my boat at full speed. (I’ve never run my boat at full speed for an entire hour. Who does that?)
At 3500 RPM I will probably run about 19 MPH and according to the YPB I will probably use up about 5.2 GPH at 3500 RPM. Multiplying this same 5.2 GPH times $5 per gallon means it will cost me about $26 dollars per hour to run my boat at cruising speed for a whole hour; and this same $26 dollars per hour DIVIDED BY 19 MPH means it will cost me about $1.37 dollars per mile to run my boat continuously at cruising speed.
At 2500 RPM I will probably run about 11 MPH and according to the YPB I will probably use up about 2.7 GPH at 2500 RPM. Multiplying this same 2.7 GPH times $5 per gallon means it will cost me about $13.50 dollars per hour to run my boat at a slow comfortable speed for a whole hour; and this same $13.50 dollars per hour DIVIDED BY 11 MPH means it will cost me about $1.25 dollars per mile to run my boat continuously at a slow comfortable speed.
[SIZE=11pt]Summarizing[/SIZE]
[SIZE=11pt]For my future 150 HP Yamaha (on my future 2014 2375 GCW), [/SIZE]
[SIZE=11pt]these are the estimates of my fuel costs:[/SIZE]
[SIZE=11pt]at about 11 MPH (2500 RPM) it will cost me about $1.25/mile; ($13.50/hour)[/SIZE]
[SIZE=11pt]at about 19 MPH (3500 RPM) it will cost me about $1.30/mile; ($26/hour)[/SIZE]
[SIZE=11pt]at about 30 MPH (4800 RPM), it will cost me about $1.67/mile; ($50/hour)[/SIZE]
[SIZE=11pt]at about 37 MPH (5800 RPM), it will cost me about $1.75/mile. ($78/hour)[/SIZE]
Please consider providing your best estimate of what you think it costs you to run your boat’s engine at WOT, at 3500 RPM (cruising speed) and at 2500 RPM (a slow comfortable speed) by using what you know about your own boat speed and simultaneous engine RPMs. If you don’t know your engine’s GPH fuel efficiency, you may be able to estimate this from the Yamaha Performance Bulletin. If a lot of owners enter their data, I think we will see some very interesting (and very expensive) results.
By the way:
($5 per gallon) times the (# of Gallons per hour) = (your fuel cost in Dollars per hour)
If you wish to participate and submit your results, you can use the following template to record your results if you want:
I have a ________ year Bennington ______________ model with a ________ HP engine.
At WOT I go about _________ MPH at _________ RPM. According to the Yamaha Performance Bulletin (Y.P.B.) I will probably use up about _______ GPH at WOT. Multiplying this same _______ GPH times $5 per gallon means it will cost me about $__________ dollars per hour to run my boat at full speed for a whole hour; and this same $_________ dollars per hour DIVIDED BY ___________ MPH means it will cost me about $___________ dollars per mile for every mile I run my boat at full speed.
At 3500 RPM I probably run about ________ MPH and according to the YPB I probably use up about _________ GPH. Multiplying this same _______ GPH times $5 per gallon means it will cost me about $_________ dollars per hour to run my boat at cruising speed for a whole hour; and this same $_________ dollars per hour DIVIDED BY ___________ MPH means it will cost me about $___________ dollars per mile to run my boat continuously at cruising speed.
At 2500 RPM I probably run about __________ MPH and according to the YPB I probably use up about _________ GPH. Multiplying this same _______ GPH times $5 per gallon means it will cost me about $__________ dollars per hour to run my boat as a slow comfortable speed for a whole hour; and this same $_________ dollars per hour DIVIDED BY ___________ MPH means it will cost me about $___________ dollars per mile to run my boat continuously at a slow, comfortable speed.
DAVID
By the way:
DAVID
