lakeliving
I'm just running hydraulic with my 200. I'm sure power assist is awesome but ours will do for now
Hydraulic is a huge improvement. The install I did was on a 150 merc EFI 2-stroke. My brother also has it on his 21' Triton fish-n-ski with a 200 EFI merc. No issues with the bigger motor either.
Significant improvement. As I mentioned in the other thread, there is little difference (as long at the ratios are the same and cable system is working well) when motor is off or in neutral. There is a significant difference when under power. There is no feedback with hydraulic. Meaning that the motor movement can't push the wheel around. This can be safety problem as well as lead to fatigue when performing water sport maneuversI have a 150 fourstroke... Would you say hydraulic steering is closer to cable steering, or closer to power steering (like a car) or somewhere in the middle in terms of ease of steering? I'm still trying to justify doing this upgrade. It would be in the $1000-$1200 range.
I have the merc 150 on mine w/ hydraulic, and coming from an older sea ray with cable, i can without a doubt say that the hydraulic is closer to power assist. Steering that sea ray was like steering a bus with no power steering. The hydraulic on our Benny is effortless at low speed, but gets tougher under power.I have a 150 fourstroke... Would you say hydraulic steering is closer to cable steering, or closer to power steering (like a car) or somewhere in the middle in terms of ease of steering? I'm still trying to justify doing this upgrade. It would be in the $1000-$1200 range.
