lakeliving
Idea is if you have an accident and a puncture, the entire toon isn’t going to sink.
Thanks. I wondered “why water” and now I know. That’d be a heck of a lot of metal blowing open in a catastrophic failure.FYI - For pressurized vessels/tanks (such as fire extinguishers, welding tanks, etc.), most manufacturers and test agencies use water to pressure test instead of air. When a tank is pressurized with water, it doesn't take much air to get up to pressure. If the tank fails, a little bit of water shoots out before the pressure is released and that is it. With air, you are compressing the volume of air many times over and the pontoon in the case is like a bomb. If a weld or something fails, you are releasing an incredible amount of air in a short time. This is incredibly dangerous.
Not dangerous at all if done properly (keeping pressure well under 10 psi)FYI - For pressurized vessels/tanks (such as fire extinguishers, welding tanks, etc.), most manufacturers and test agencies use water to pressure test instead of air. When a tank is pressurized with water, it doesn't take much air to get up to pressure. If the tank fails, a little bit of water shoots out before the pressure is released and that is it. With air, you are compressing the volume of air many times over and the pontoon in the case is like a bomb. If a weld or something fails, you are releasing an incredible amount of air in a short time. This is incredibly dangerous.
