Boatingbob
- Messages
- 42
- Reaction score
- 1
The marina I use says their gasoline is 10% ethanol. Is their anything I should do in light of that?
Thanks.
Bob
Thanks.
Bob
Ahh, the great ethanol debate comes up again :lol: Personally, i do not like ethanol unless i used it in an alcohol powered race car. But, since the powers that be have forced it upon us, we will have to live with it.
Modern marine engines fuel systems have been designed to use E10 fuel, check you engines owners manual to be sure.
I have run E10 in our Yamaha outboard with no problems. If you would like to find out if 100% gasoline is available in your area, go to puregas.org.
It really comes down to personal preference and how far out of the way you are willing to go to find 100% gas
Haha, "Bulldog's Blend" , what makes it even funnier is that we used to own a gas station and could have ACTUALLY had that!! I mean I like the idea of saving 10 cents a liter on regular fuel as opposed to premium, and I'm not against ethanol, our gas station was actually the only one around dispensing fuel with it before the gov't mandated Manitoba and I have used it in everything else I've owned without ever having a problem, but you guys scare the CRAP out'a me with all your talk, and watching YouTube of course!!To make "Bulldog's Blend", just put both pump nozzles in your tank at the same time. You'll also fill up twice as fast. :blink:
So do you just use 87 octane or 91?I own the same engine & use Marine Sta Bil evry time I gas up. I do suggest gassing up before you go out & not afterward. My dealer agrees also.
OK, here's the deal...Ahh, so here is my new dilema, ordered a yamaha 200hp SHO, yamaha says with the 200hp and 225hp you get the best performance with 87 octane fuel and 89 in the 250hp, and that using a 91 or 93 will actually give you worse performance and create carbon build up. So, do I get 91 without ethanol in it or get 87 with ethanol?
Derrick
This is a picture of the bottle:We have two fuel additives: Ring Free PLUS and Fuel Stabilizer & Conditioner PLUS. The “PLUS” includes reformulations for our standard Ring Free and Fuel Stabilizer & Conditioner.The Ring Free Plus protects against the corrosive affects of sulfur salts in E10 (10% ethanol-blended fuel) on electronics parts and fittings in the fuel system. It is highly recommended for all electronic fuel injected engines (EFI). The Fuel Stabilizer & Conditioner PLUS helps protect fuel system metals affected by E10, helps to prevent fuel oxidation that results in gums and varnishes and keeps fuel fresh and potent up to year of storage. Fuel Stabilizer & Conditioner PLUS is recommended to be used at every gas fill up, not just for storage.
