keithkz
I'm pretty sure I have a 15.5 x 17P.
Power Tech's website says to decrease pitch 1-2 inches if your prop has extra cupping. That explains a lot of the difference, as you said.I went back with a 13 pitch 4 blade with aggressive cupping. With a 115 I would think a 13 would be right as well. The diameter and cupping make a lot of difference and are just as important. I went with "Power Tech" props. They have been a outstanding company to work with. If you call them and tell them what your current boat, motor and prop is, then tell them what you want out of a prop change, they will recommend the prop for your needs. The BEST thing with them is that if the prop doesn't work like you expected, they will let you send it back for another with only a restocking fee. I doubt this happens as they got mine right the first time. Also be sure you get the "cushion lock hub" system for their hub as it greatly reduces the stainless backlash problems with the new four stroke engines.
Very few pontoons are running quads. And if you notice on the manufacturers' performance tests on pontoons/tritoons, they're running 3 bladed props. I think that most 4 bladed props are for bass boats looking for acceleration and mid range power.Ok you guys have me really interested now that you're talking about props. I have an I/O (see full description at the end of this post of my boat) with a 3 blade stainless prop....I want to say 15.5 x (???). Would going to a 4 blade be in my interest?????
I knew it would give me more hole shot but what did it rob you off of your top end? I will eventually do some tubing behind it one year (when my 18 month old twins are old enoughI bought a Power Tech 4 bladed stainless steel for our I/O last year. I called them and they recommended the size. I have been very happy with it. It has increased the hole shot and lets me cruise at 200-400 less rpm at the same speed. Went from 3200-3400 to 3000 rpm. It is great for tubing. It is also great for the debris we have in the lake this year. We hit several sticks/logs yesterday and no damage to the blades
