I know the questions are coming about the 350 so here's what I can tell you after a short ride yesterday. The boat full of fuel with just us 2 on it hit 51 mph which is low compared to the other boats we test drove but.......
There's 2 issues that have to be addressed, first off the motor is mounted to low, it needs to come up 1-2 holes. Secondly I don't think the prop is exactly what the boat needs, it has a 15x15 enertia prop and its letting the motor turn 6550 rpm's with only 2 people on board. Later we had some friends and our daughter on board which was a total of 6 adults and still had 40 gallons of fuel and it turned 6450 rpm's and ran 49 mph.
Once I get a little more time on it I will get it back to the dealer and get some adjustments made but overall the motor is amazing, it's very quiet and very responsive.
Ok. Educate me. I have never had an outboard. How do you know the motor is too low and what does changing the height do? Thanks.
great boat!
The propeller is sitting behind a large pontoon. If it is too high up it won't grab; if it is too low the anti-ventilation plate will be too far down in the water, and it will cause too much drag. Here's a great article that will explain it better:
http://www.boats.com/how-to/the-outboard-expert-boost-speed-with-outboard-engine-height-adjustments/#.WPoG89LysaY
great boat!
That's a good starting point. I'd get to 20 hours before making a lot of changes, which is what they recommend on veradoclub.com. The nice thing is the Enertia comes in 1" increments so you can dial it in for exactly what you want. I'd think there is 4-5 more mph there with the right setup. My 250 Pro is mounted 2 holes up, with an 18 pitch Enertia, no blow out issues at all. Top end is ~51 @6250, lightly loaded.
That thing is freeeeeekin sweeeeeet!!!!
Todd,
Great looking boat, well done. Thanks for the info on the mounting, as I am new to outboards too. This will be the first one I have owned. Had a stern drive Cobalt, and now an inboard on the Mastercraft.
Also, what do you think about the sound system? Didn't you go with Roswell?
