sunnyside360
According to Evinrude propping literature and my boat dealer, the Rebel prop gives better low/mid range RPM performance and economy than the Viper but Viper gives a little more WOT speed. I've researched props ad nauseum also for my 2014 Etec 225HO and have concluded to stay with my current Rebel 17" prop which tops out around 46.5 MPH at 5800 RPM with 2 people and a full tank of gas. Many test reports with this engine on pontoon boats have logged around 50 MPH with the Viper prop but I rarely ever run WOT. Found also you have to be careful with the data since the gear ratio for some Etecs used to be 1.71:1 and most if not all are now 1.85.:1. Still, I may take my dealer up on his offer to try the Viper prop even though he prefers the Rebel.Thank you Sunnyside360! I did a little research, and switching to a rebel prop would probably give me the top end I want, but assume I'd lose somewhere else? Right now the boat planes instantly and is extremely responsive to the throttle. If the boat ends up at only 41 I'm okay with that. My solution would be to upgrade to an ESP with a 250 sooner!![]()
