LIST YOUR SPECS HERE
Bannermans Bennington
* Boat Model--------------- 22 SVSR
* Model Year---------------- 2021
* Tube Option-------------- SPS 25" lifting strakes (certificate for max of 200hp) Wave Shields
* Power Option------------ Merc 150
* Prop Specs---------------- Merc Enertia 15.3 x15" Stainless
* Performance------------- 40 MPH (GPS)
* Engine mounting------- Not sure......
Gordons Bennington 24 24RTSBASD (Bowrider)
* Boat Model--------------- 24RTSBA
* Tube Option--------------23" Outer tubes, V styles center
* Power Option------------Yamaha 300
* Prop Specs----------------Yamaha 15 by 14.5
* Performance------------- 42 MPH @ 6200 (GPS)
* Engine mounting------- Top hole
Sorry, trying to figure out the posting system. Duh.
Mine is a dog. It jumps out of the water but feels laggy. From 5000rpm to 6000 there's no change in speed. That's just with 1/2 tank and the Queen and me. Feel like I am slipping. I had prop guy put a bit of cup in the prop which dropped max rpm to 5000 (yikes) : speed the same. Propgod says to go 13.5x12. But, with the 14x13 with no cup I was at 6100, so decreasing seems counterintuitive. Unless it was slipping like crazy, which is what yall will say. Any ideas? Max hp according to the sticker is 70. Mounted all the way down. I have one of those center pods that holds the tank, and that makes the wash very turbulent. Afraid if I lift I'll be in air.
Last tidbit. Previous owner kept it in the water with bottom paint. It was pretty bad when I got it. I've washed it very well tho admittedly there may be a little crud remaining on the inside of the toon, but hardly any. And, I have no underskin.
Help please
  • Boat Model --------- 20SL
  • Model Year --------- 2013
  • Tube Option -------- 2 x 23 inch round
  • Power Option ----- Yamaha F70
  • Prop Specs ---------- 3 blade aluminum Quicksilver 14 x 13
  • Performance ------ 17 mph @ 6100 rpm on GPS
  • Boat Model --------- G 23
  • Model Year --------- 2018
  • Tube Option -------- Tri 25" with SPS Plus Package
  • Power Option ----- Mercury Verado 250 Pro Supercharged
  • Prop Specs ---------- 14 1/4 X 17 Stainless Steel Mercury Enertia
  • Performance ------ 48 MPH @ 5700 RPM. WOT
  • Cruise easily above 40 MPH Fully Loaded
Your WOT RPM seems a bit low.
  • Boat Model --------- 26 LXSB CoCaptain Double Bimini Always Up
  • Model Year --------- 2021
  • Tube Option -------- Tri 25" ESP .125
  • Power Option ----- Mercury Verado 350hp InLine 6 2.6L
  • Prop Specs ---------- Enertia 14.7x16P RH
  • Engine Mount-------3rd hole from top.
  • Performance------ 48.6 MPH @ 6310 RPM. WOT Fully Loaded, 1/2 Tank, + 3 adults, 98 degrees, downwind.
    • 42 MPH @ 5990 RPM 1st Season, WOT Fully Loaded, Full Tank, + 5 adults - 108 degrees
    • 45 MPH @ 6218 RPM. WOT Fully Loaded, Full Tank, + 5 adults - 95 degrees & damaged prop Post 1st maintenance
    • I estimate 2mph loss per adult, per 1/2 tank of gas, Bimini Up, every 5 degrees above 100.
  • Fun Factor-----------off the charts
We're starting this thread to collect everyone's specs in one place. That way, anyone wanting to know how the different options will affect their own boat just can look in one spot to see everyone else's real world experiences.
Just hit the reply button to this post, which quotes the format, and edit it to fit your specs. Simple and easy.
Make sure you get in the small details like the size of your pontoons, do they have strakes, the brand, model name and HP; that sort of thing. If you happen to have a specialized option like the ESP or Dual Elliptical setup, or perhaps are running a jack plate, mention that too.
Oh, almost forgot... Let's try and keep this thread "single purpose". If you are reading the thread and realize you have a particular comment or question for someone in regards to their specs & numbers, just start a thread in the forum and make sure to include the person's Online Name in the thread title so that they know you wanted to ask them something.
That's about it. Have at it! B)
  • Boat Model --------- 24LXFB CST
  • Model Year --------- 2022
  • Tube Option -------- Tritoon with ESP
  • Power Option ----- Mercury 300HP DTS 4 Stroke
  • Prop Specs ---------- 14.7 X 16P Stainless Steel
  • Performance ------ 47 MPH is top speed I've captured, 45MPH with 8 people and full tank of gas
  • Other Options ------ Power assist steering, digital throttle, sealed lifting strakes, center tube fuel tank, in floor storage, dual batteries,
  • Boat Model --------- 2275 RL
  • Model Year --------- 2007
  • Cool Options -------- Changing room with porta-potti, LED bimini lights & courtesy lights, docking lights, USB ports, Kicker bluetooth stereo & speakers, flag pole/fish pole holders on tow bar, center storage tube
  • Tube Option -------- Three 25" w/ Strakes, full underskin, performance package
  • Power Option ----- Yamaha F150- 150hp - 4-Stroke
  • Prop Specs ---------- 3 Blade Quicksilver 15x17P
  • Performance ------ 34 mph with 8 adults, bimini up, 2 flags flying and full coolers
  • Boat Model --------- 22 SLX 2X
  • Tube Option --------Twin Elliptical
  • Power Option ----- Yamaha 115 (2)
  • Eng. mtg height ----1/2 above top
  • Eng. mtg offset -----10 inch back
  • Prop Specs --------12.5 X 19 Alum
  • Performance ------ 50 mph @ 6200
The hull configuration was changed to reduce drag. Top speed is limited by porpoising even with modest trim levels. Higher top speeds have been momentarily observed until porpoising became excessive. Still working on the porpoising problem.
1979 prototype
2.3L V6 with 114 horsepower, or upgrade to a 2.8L V6 with 135 hp.
5,100 pounds
87 MPH ..... on land.
Mk1 European Ford Granada mounted on a fiberglass hull
2277 RSFI
25” pontoons
115 Yamaha 4 stroke
Aluminum 13 1/4 x 17 prop
25.5 mph @ wot 5900 rpm
One person, clean toons, Bimini in boot but up. 3/4 tank fuel, empty boat.
Steve’s boat “Group Therapy”
  • Boat Model --------- 24SSRX
  • Model Year --------- 2015
  • Tube Option -------- Tri-Toon with SPS package. Wave guards, lifting strakes, fully skinned under the deck.
  • Power Option ----- Mercury Verado 200HP Supercharged 4cyl.
  • Prop Specs ---------- 15” Pitch 3-blade Stainless
  • Performance ------ 40 MPH @6000rpm
Victor's Boat
On lake Wedowee in Alabama. ONly seen one other Bennignton on this lake. Nice to be high class w/o much competition :cool:
  • Boat Model ---- 23RSB
  • Model Year ---- 2018
  • Tube Option ---- Tri with ESP and aluminum wave tamers
  • Power Option ---- Yamaha F300
  • Prop ---- TBD
  • Performance 45 MPH (GPS) @ 5600 RPM - one rider and 1/2 tank of gas, 35 fully loaded
JnSLarto62's Boat
  • Boat Model --- 27QFBWAT2SD
  • Model Year ---- 2021
  • 2 - F300NSB Yamaha Motors, DEC with Full Maneuverability
  • 58 mph @ 6000 RPM with half tank fuel and 4 people, 50 mph with 10 people fully loaded
  • Props — Yamaha Saltwater Series 19-T-15 1/4
  • 83 gallon fuel capacity
  • 5 gallon fresh water wash down
  • Tube Option ---- Tritoon with ESP+ package, wave tamer to bow, salt water package
  • Twin 54" Ski Pylons
  • Cladded Powered Arch with Black Bimini
  • Midnight Black Primary Color with Rossa Red Second Accent
  • Rossa Red / Sunset Red Custom Vinyl seats
  • Center Pontoon Storage
  • Blackout Luxe Package
  • RGB Controller Lighting - Exterior, Toe Kick, Underwater
  • 1243 Garmin Chartplotter, CL5 Yamaha Display
Boat Model: 22SSRXP
Model Year: 2019
Tube Option: 25' SPS with lifting strakes
Power Option: Yamaha F200 2.8L I4
Prop Specs: current--Solas 14.25 x 17P Stainless Steel switching to????
Performance: 38 gps @ 5000 rpm. 4 people 3/4 tank of gas
Engine Mount: Top Hole
Any prop suggestions to speed up my boat?
much appreciated!!!
I know it’s years late, but your boat should be doing 30 mph with very little effort. Sounds like a slipped/bad propeller hub.
2022 SXSNP
25” Twin Toon
Lifting Strakes
No underskin
Yamaha VF90
PowerTech SWW 13.5” 12p
32mph at 5900 RPM on Garmin GPS with 2 people and MinnKota Terrova 24v including batteries.
Original Yamaha K prop slipped especially when loaded and only went 28mph at 6200 RPM.
Other PowerTech observations
Trolls to fast at idle, 2.5mph.
Runs great when loaded and just cruising, 22mph at 4200rpm
Haven’t pull tube yet but hoping the cupping helps holeshot.
Much smoother hub, shifting is ultra smooth and quiet, no clunk.
It is heavier and along with the cupping adds a bit of noise ass it chumps the water when going slow.
