Speaking of engine trim, please tell me how far you can trim your engine and how it relates to the trim gauge? I realize that you can only trim up an outboard on a pontoon so far, but with mine full up to full down and the guage only moves about 1/4 of the range displayed. I think it is not set up correctly. What do you think?
TBH, sounds like you are running right where I’d guesstimate based on your set up. The ETP hull can sit a little lower in the water, so potentially raising the motor up slightly could perhaps give you another 1-2 mph, but it also might make it cavitation a little bit in turns. Based on your RPM’s and performance, I would not spend the money on trying out different props because I don’t think it will end up making an appreciable difference at all.I have a 2021 21SX, Express Toon Package with a Yamaha F115LB. It is new this year and our first pontoon boat. It has an aluminum 3 blade prop on it, but that’s the extent of my knowledge. LOL. I have had it full throttle a few times (after break-in of course) and it runs great and maxes out at 6,000’ish rpm. With my wife and I on the boat, normal gear, trimmed fully down and full tank of gas, it runs 32 mph. We do boat on a small lake, about 1,500 acres of surface area, so the water is usually fairly calm. We’re really happy with the set-up. BTW, the engine is mounted in the first hole.
Cost me about $150 to find that out with my 115.. Kinda cheap though considering. Only got about 1 MPH going from a 13.5-12P to a 14-13PI would not spend the money on trying out different props because I don’t think it will end up making an appreciable difference at all.
Our Bennington/ Regal dealership will not allow you to even sign the paperwork without a long drive in said boat-No Exceptions. I took delivery of a new Regal and they went with us, told me to haul ass, cut it hard etc...I appreciate your reply. I was not able to take a ride on my new boat upon delivery due all this COVID stuff going on this year.
I talked with my salesman as my boat was originally outfitted with a 13 inch pitch prop. He said he thought it was correct but got me a 15 inch pitch prop as my old boat did not experience this problem. I had one nearly identical as the 2001 you reference on your post.
The 15 inch prop is better but the problem is still there. Blow out over 4200 rpm unless the water is flat. Even then I have to slowly walk up the rpm and can not get over 5000 rpm before it blows out.
The cavitation I experienced with the 13 inch pitch prop was bad enough to cause the coating on the blade of the prop to delaminate and peal from the aluminum.
The engine in mounted with only one additional hole to lower it which will only get about 1/2 to 3/4 inch drop
The salesman tells me the water flow between the tubes is just so turbulent due to being a pontoon.
I feel like there has got to other people out there that have experienced similar issues.
