Pontoon protection Metal Jacket XL
NCLakeGuy
I had researched and read a lot about Sharkskin to help protect the pontoons and keep them cleaner. It seemed some had success but not when the boat spent a lot of time in the water. Mine stays in a fresh water lake most of the time just coming out for maintenance and deep cleaning. Some more research and talking to the producer I decided to try Metal Jacket XL on my Q23. They highly recommend it be installed by a certified/trained dealer but I would have done that either way as the boat must be lifted to cover all the surface area. In this area it is Race City Marine in Mooresville. Picked it up a few weeks and put in the water Easter. I will post updates as I live with it. One of the dealer employees has had it on their toon for about 2 years, it stays in a lake also, and he wipes the bottoms with a microfiber cloth when out and he reports it is holding up well so far and comes really clean.
I usually recoat mine with Sharkhide every other year. I've got my dealer looking into metal jacket.
If yours previously had Sharkhide did it have to be removed?
No the boat did not have Sharkhide but they would have needed to remove it. Mine was acid washed and then lightly polish more to insure a smooth surface and good adhesion. This is basically a spray on product.
Thanks for posting this project. Looks very interesting. The website seems to imply that it can be a do-it-yourself project with a micro-fiber towel. I have a new pontoon and am considering some type of treatment before its first launch. As a side note, I always wonder why the tubes are not painted like many high-end AL fishing boats.
I am uncertain of the product you are looking at on their site as they have several from what I did to basically what I would call a ceramic coating. I had a lengthy conversation with Frank Ugarte at SG prior to making my decision. Only time will tell if it was the right one!!! I would think even if DIY the boat would need to be suspended to cover all areas or moved around allot on the trailer. I will update with my results!!
It looks great NCLakeFuy!
I am no expert and looked at the MetalJacket XL product and its technical specs / application instructions (link posted below).
I am not familiar with the product, but find it interesting. I have Sea Legs / Ultra Legs if I was adventurous enough to try it, assuming it is for sale retail. The prep / cleaning / tape work might be above my interest level. I would guess some lifts that support from under the deck could also work.
You Tube showing application. Looks like they have lifted the pontoon on blocks while on the trailer. This video might be for the non XL product, but the instructions seem to be the same in the product specs.
I am not seeing any dealerships in my area (MN) and it doesn’t look like you can purchase it retail. Guess I am back to Sharkhide but will be interested in how it works for NCLakeGuy. I was hoping to find something before using the new pontoon. Thanks for sharing.
Update. So my boat was in Lake Wylie for the last 10 weeks or so. Build up was definitely happening and I was a little concerned. Reached out to manufacturer rep I had talked with prior to purchase and he said in water scrub with soft to medium bristle brush. Went to sandbar this weekend and first swipe of my small brush medium bristles (2"x 4") and not a lot came off, pulled back over same area and a lot more came off....so on my knees or standing beside boat floating I went around the boat scrubbing with the leverage I could get one arms length back and forth for about 2-3 minutes a section. I went from water line down to center of outside pontoons. The feel and sound you could tell when it was getting smoother. Water is not crystal clear, sun is up and boat is rocking from waves so looked at the underwater portions best I could. Did not go all the way between the toons on both sides as I had a time constraint. But was quite happy with the results given time, effort. there are still some things the brush would not get off and my finger nail did so I will add a 2" plastic razor scrapper like we use on cars at the shop to get that off next time. I believe it will work. So while not great pics here are a few before and after. Overall very happy and I will put on trailer sometime in the next 4-5 weeks to see what my pressure. First pic is result other two are prior.
IMG_3665.jpgIMG_3666.jpgIMG_3667.jpg washer can do.
Thanks, I'm considering having it applied next off season.
My Benny is generally in the Lake about 4 months in the summer. Sharkhide was applied when new, that worked great year 1, worked well year 2. We would use about every 2 weeks, and would find a calm cover, used our vest as diaper floats, and used large scrub pads (attached) - a quick back and forth on each and back to "like new" - 2 of us done in 15 minutes (5 minutes per side). Year 3 we had to put some muscle into it. Year 4 could not find a local Sharkhide Rep, so had the detailer put their product on - not nearly as good - but they actually recoated with something different - No Charge, they realized their product did not work so well on Aluminum - so will report back on what it is and how it works (Launching this upcoming weekend finally). But for a town (Lake Havasu) built around a lake and boats - still have not found a service that will lift the toon to get a full application of anything done.
Mine stays in year around and I believe the amount of algae, slim, bloom, mold etc in Wylie is very high compared to many lakes. So unfortunately the hull is another source of attachment. I too will use a much larger brush like you use next time! I did not want to buy something until I was convinced this would clean easily. When I get the boat out for a pressure wash I will get some better pictures of how bad it was. The pics do not do it justice. And I have not relationship or vested interest in this company. :)But very satisfied so far!!
When we kept our boat in the water every time we took the boat out we would take time to wipe all 3 pontoons! We will anchor in a no-wake zone Cove eat lunch and then jump in and start wiping. Didn't take long and we kept it clean of all the crap that could have accumulated on them!!!
