Mahalo Party Barge for your informative response. I thought spinning a 135/8 x 14 @ 6450 rpm, and 26.6 mph with a gear ratio of 2.15 where the WOT range is 5500-6300 that I would have to increase the pitch by at least 2 ", not decrease the pitch. But I guess the shape of the blades makes a huge difference. Thereʻs no calculator for that, only to spend money to try different props. Our intended use of the tritoon is mainly cruising @around at 10-15 mph, and some very occasional tubing/waterskiing.
I did run my numbers through Mercuryʻs slip calculator and got 33%. What is the acceptable slip % for my tritoon? How do you like the flow torq hub? What kind of pontoon boat do you have? The SDS prop shifting is so smooth. BTW, I remember from your previous post that you were a C-141 pilot, I flew fighters in the Hawaii Air National Guard, and retired as a captain from Aloha Airlines.
I agree with you that I should have started with a cheaper aluminum prop, but knowing that I wanted a SS prop, and after all my online research, lead me to think I could jump right to a SS prop This has been a very humbling experience for me. I still want to achieve my goal from the 4/9/21 post: "I hope to achieve about 5800-6000 rpm without trim; with trim 6100-6300rpm, and 30-35 mph. with 2-4 people and 3/4 fuel on board." I believe that this goal is firmly within reach.
