I think this falls under PB's sentiment. It looks like a pretty good package - heavier springs, auto locking diff, optimized gear ratio, transmission cooler etc. - but I wouldn't search the ends of the earth or pay a big premium for it unless you had a heavier boat.I'm looking at the Tahoe and Yukon's with the 5.3l v8. The Max Trailering Package appears to be not very common in available dealer inventory, in general.
Considering the 3k lb dry weight of my pontoon, trailer, motor, I'm trying to figure out if the Max Trailering Package should be a deal breaker or not.
I am certainly going to continue hunting for one with this package, but I am trying to figure out how much of a deal breaker vs. nice to have this should be.
2900 lbs seems light, but agree the 5.3 V8 4wd will be AWESOME! Per Benny Build Standard Options - boat is 1,900 and don't think that includes any extra's. Add the extras (battery, bimini, ski bar, etc) motor, gas, trailer, food, beer..... but well under limits of the truck you are looking at!After all the research I've done at this point I've got my target set on a use / offlease Yukon or a Tahoe with a 5.3 l V8 with 4wd and the max trailering package. The boat dealer told me the pontoon plus engine and trailer dry weight is just over 2,900 lb so I feel like with this size of vehicle I'm setting myself up for a comfortable driving and towing experience.
I’ve owned two Yukon’s in the past, and a 4WD Yukon/Tahoe will take care of your needs just fine.After all the research I've done at this point I've got my target set on a use / offlease Yukon or a Tahoe with a 5.3 l V8 with 4wd and the max trailering package. The boat dealer told me the pontoon plus engine and trailer dry weight is just over 2,900 lb so I feel like with this size of vehicle I'm setting myself up for a comfortable driving and towing experience.
Does the Yukon 5.3 have the AFM or DFM? Read over at BBC (bass forum) that it can cause problems so an ECM flash delete might be something to consider.
This is what happens when you try to get too cute with technology. I get it - EPA and CARB may drive some of these things, but adding more sometimes means more can fail and reliability suffers. In the end, was that extra 1mpg really worth it?Yes, they sure do. Some family of mine had a Tahoe and the AFM system started acting up, I think it was the lifters. They took it to their local mechanic, whom said they would have to replace the the engine for about $7500, or do a full delete kit (new lifters, gaskets, etc) for around $3500 installed and it would run in V8 mode full time, with no real detriment to fuel economy.
It's running like a top just after 50K miles since the AFM delete.
I know an Yammie F250 with 1500+ hours, no issues and like-new compression. Keep oil in it and you'll be fine.And my F250 (OB) is old tech and not as sexy as a new V8 Merc, but if I can get 2000 reliable hours out of it as many people do I'll be happy as a clam.
You should be plenty good if you went with some version of LT rated tires (Light Truck). One of our knock-around vehicles is a Dodge Journey that I will likely never use of towing for a couple reasons, not the least of which are the car oriented touring tires. They are good for MPG, but not so great for sidewall stability. If you have time, grab one of these:I'm going to be picking up my first bennington (22 svsr sps) here in the next month or so and plan to tow it 200 miles with my old '01 GMC Sierra 5.3 4x4. She's been well taken care of and I just had the brakes, tires, bearings replaced. From reading this thread, hopefully I have no issues!
