2011, no warrantyWhat year is your Bennington? Covered under warranty?
It does look like that one, only one speaker failed. I tested wiring, Bad!Did you lose only one speaker or did you lose a pair? My last boat was a 2011 and the factory Sony stereo had an annoying default -- if the radio lost power, it would default to a 4 speaker set up. So both rear speakers would be silent. You had to drill down several levels in the settings to find the option to enable the rear speakers. So if your radio looks like this (sorry, I can't make out the model number in this crop), look in the manual for the setting to enable the rear speakers.
I lost my 1 front speaker on the bench. I have a speaker on port bench and port aft bench (all three of these work). I removed the front speaker.Did you lose only one speaker or did you lose a pair? My last boat was a 2011 and the factory Sony stereo had an annoying default -- if the radio lost power, it would default to a 4 speaker set up. So both rear speakers would be silent. You had to drill down several levels in the settings to find the option to enable the rear speakers. So if your radio looks like this (sorry, I can't make out the model number in this crop), look in the manual for the setting to enable the rear speakers.
did you ever run the wire? i have the same issue. front speaker wire badHas anyone lost rear speaker due to bad wire. If so how do you replace wiring to rear speaker?
Check your harness connection at the radio. I get a dead speaker or two every so often and I jiggle that connection and they start working.did you ever run the wire? i have the same issue. front speaker wire bad
