LaurencetheAdventurer
I am still learning and trying to figure this all out - I am not clear if you are using 1 or 2 1000.5 amp"s", but assume 2.
This allows an upgrade path to better rear-facing deck speakers, though it slightly underpowers the bass, depending on how loud you want it.
I have not wired my system yet, but my comment is on the power required to run two 1000.5 amps - it is a lot... depending on how loud you run it (which I assume is LOUD based on 2 1000.5 amps - most users report 1 has been adequate). Be sure you address this aspect; most certainly, you will need to move to a lithium house with an Orion DCDC charger and have a way to externally recharge the batteries between uses.
Keep us posted - I am very interested!!!
