50 hp. I'm really the first to write that?whats the difference in mileage between the 150 merc and the 200 merc
He was asking for MPG not HP... easily mistaken I know. From what I have read the milage and performance differences are minimal between 150 and 200 regardless manufacturer.50 hp. I'm really the first to write that?
And as Gilda Radner once said: "Never mind."The F150 hp motor will be slightly better on fuel than the F200, but not enough for an operator to tell the difference. The F200 is essentially the same motor with a higher compression ratio and a larger throttle body (in diameter.) With a higher gear ratio, the F200 will run at slightly lower rpms at the same cruising speed.
. I read it too fast. Didn't see the mileage word. Oops.He was asking for MPG not HP... easily mistaken I know. From what I have read the milage and performance differences are minimal between 150 and 200 regardless manufacturer.
that sounds good to me. its a new motor. boats rated for 200 hpThe merc 150 is a clean sheet new design. Overbuilt for reliability. Simon Motorsport is working on a reflash for it. If you have the new 150, I would wait to see what HP increase Simon comes up with.
Ok, I can get you a 17" prop for you if you do the Simon upgrade. Free of charge. On the house Dan. Cause I'd go with a new one if I go with Simon as well.If I got a new ECM from Simon for our Merc 150 fourstroke, then I'd have to get a new prop too, and I don't think Todd has any left.
