2019 fuel gage issue
Frank25RSD
I have a 2019 Bennington less than 1 year old and fuel gage not working caused me to run out of fuel
Took me 30 minutes to prime engine once I got fuel in the tank.
Anyone know a fix on the fuel gage ke have the same issue?
SEMPERFI8387
York, Pa
Dealer/warranty.
David G
my 2020 gauge dont work.
TwoTone
Somewhere in Cabo... or Central Oregon...
I’m running a 2019 Merc 350... My fuel gauge also quit working... One of the digital menus on my starboard Merc gauge is how many gallons have been used... It’s an actual Merc readout from the engine verses the fuel gauge which reads from the tank... I always leave with a full tank and know right where I stand on any given trip... This suffices until the season is over, then I’ll take it in to have the tank float repaired...
kaydano
Pretty sure the fuel sender is a variable resistor, so if you disconnect the wires at the guage, and hook up an ohmmeter, the resistance should vary between full and empty. If it doesn't, that would at least tell you if the problem is the guage or the sender.
