Adjustable Seat Pedestal project.
Major K
Cincinnati
5E5F4B28-3890-4B41-AEA8-416EA5E5F164.png C1B48DA8-AD11-4E70-8B92-EB5C2BB9FDA2.jpeg 7DAD18A3-09D7-4223-9322-8F237E16F60D.jpeg DBE8403A-D352-4A46-AB14-7CA2A0265079.jpeg E446ECC5-B4D9-4028-B83B-60F4BCEC6AF5.jpeg I finally got around to changing my factory fixed height pedestal to an adjustable height one.
All holes lined up, no drilling no cutting. The factory pedestal sat too low for me.
The lowest setting raised my seat up about 3” which was perfect for me at 6ft 4”. Keep in mind, it is a 3 to 4 beer project. You will also need a helper to hold a screw driver.
14 bolts 9/16 hold the side skirting on and 6 screws and nuts hold seat on. You will have just enough room to get your hand under the skirting to reach the bolts. Someone suggested that you tie a string to ur wrench Incase you drop it, which was a good idea. I also suggest sliding a thin piece of cardboard on top of toons below pedestal when removing nuts and washers just Incase you drop one.
kenr
2013 gbr2250 just upgrade mine and love it to an adjustable one from springfield part #1250450-l works great nice to be able to move up or down
Michiman
Okemos, MI
View attachment 25466 View attachment 25462 View attachment 25463 View attachment 25464 View attachment 25465 I finally got around to changing my factory fixed height pedestal to an adjustable height one.
Major K, thanks for the pictures, suggestions and narrative of your project as it likely will be helpful for others in the same situation. Glad you're happy with how it turned out!
