Tooncrazy
I have a 2015 2275 GCW and want to add a powered subwoofer to my stereo system. Has anyone here done this with their 2275 GCW? Where did you mount it? Were you happy with the results?
Thank you.
Thank you.
How is that mounted? Did you screw the plastic clips to the floor and use the straps that go around the tube?Did it on the 2375 RCW, I know it is not the same helm, but I had mine mounted under the helm in the storage.
As far as the results, I am working overseas so I have not heard it, but my installer and my wife said it is unbelievable, it sounds great. I have the 10" 10250D.
Yes. I will try and have my wife get pics. I also bought some 3m hook and loop velcro just in case I wanted to use that instead. My wife said he used the straps.How is that mounted? Did you screw the plastic clips to the floor and use the straps that go around the tube?
Yes, I am going to have to see how this works outI'd like to do the same, but worried about my S helm door rattling like Nick's rattlesnake...
The other choice is under a seat, if it would fit.
He used 8 gauge wire. You need one power and one ground. The ground should be a short run and connect close to the sub/amp. This is right from the installation instructions from Bazooka. The unit comes with a wiring harness for the other connections, but I did not do it so not sure how much that entails. These instructions say to use 12 gauge, but I was told to go bigger.Interested to hear how it works out. I've thought about doing the same but my biggest hesitation is running new wire from the battery to the helm with the wave shield and everything in the way. What gauge wire and how many do you need for a little powered thing like that bazooka tube?
Yes, ground does not go to battery, just ground block under helm. If you run to battery you can have problems such as inducing noise into your system.So if I understand that correctly, the ground wire doesn't go back to the battery but just to another ground wire/block under the helm. So just the one 8 awg power wire back to the battery?
Not sure, but I am not an electrician. Bazooka specifically says not to do it. If you go to the website like 12volt dot com or something like that they tell you not to do it either.I would run ground back to battery.
I would always run it back to the battery. The path to ground should have at least as much wire gauge as the positive connection has. The other grounds under the helm would likely be lower gauge for some connections. From a noise standpoint, the answer is "it depends". You're balancing between the substantial noise benefits of a true "star ground" with preferably short connections, or a longer line length which can act like an antenna. In general I'd prefer +/- same gauge, same length direct to a battery.Not sure, but I am not an electrician. Bazooka specifically says not to do it. If you go to the website like 12volt dot com or something like that they tell you not to do it either.
I just looked it up, the Marine unit instructions says it is a chassis ground. It specifically says they do not recommend extending the grounding cable to the battery, says it can cause ground loops. So, do I not follow the instructions? This has me confused.Did you buy a marine based bazooka? Marine instructions never call for a chassis based or block based ground.
Your taking a huge risk on blowing engine circuits on the marine engines by not using proper grounds and power runs to the battery on items that draw above 15 amps
There are two huge audiophiles that have done their homework and bulldogs one of them.
