1trotter
Blink XT cameras from amazon are fantastic.
Mooring auger pole would work or I would use cinder blocks with chain (around blocks) and rope from chain to tie off (and you can untie and leave the blocks and chain in the water through the winter). We do this to hold a sculling rowboat and neighbor does the same for a sunfish. Im lazy and wouldn’t want to screw and unscrew the augers every year.
I would go as far out with this line as your dock length. (Doesn’t look like 36 feet would be long enough).
And tell the neighbor to move and lengthen his dock.
Since the rental dock does not have a lift, should you be concerned that an inadequately tied off rental boat might come loose in a night storm, and bang into yours? In which case, since your boat has sealegs, can’t you park it on the other side of the dock? Or would that make getting into your boat more difficult?
