Since I am not smart enough to add the picture to my message, take a look at my gallery and see if this type of issue should worry me? Ever since I found my wave shield rivets popped out and a section of hte waveshield bent up near the front of the motor pod ( twin elips setup), I have now noticed a bubbling line on my rear teak flooring. No damage to motor pod or pontoons can be found anywhere. Just a bent waveshield to the starboard and port side of the motor pod. I noticed wet carpet between the 2 rear facing loungers (2275 rcw) and wondeed why? I have since made afield repair to screw down the bent waveshield and have not had any further wet carpets. now this bubbling deck bothes me.
Question for folks without a waveshield.... Do you get any wet carpet between the rear loungers? if you don't have a waveshield, what stops the underdecking from getting wet when running on plane and or into large waves?odd
Thanks
Todd
Thanks
Todd
