kaydano
- Messages
- 4,287
- Reaction score
- 2,164
I'm pretty sure engine break in has been discussed here a few times, but I searched and didn't find it, plus if I recall, the question on how aggressive you should be wasn't answered....
For example, according to Mercury, for the first X hours you are supposed to vary the engine RPMs but don't exceed XXXX rpms. So, the question is, should you slowly work the throttle up and down that rpm range, or should you do it aggressively (as in flooring it, then stopping when it hits the high end of the range and back off quickly back down to idle)?
Thanks!
Thanks!
