Same hereI use 4 8.5" fenders at the dock but also carry a couple of larger fenders as I find they work much better when rafting up
We did. Used magic eraser and simple green to clean every so often. Now have dark blue ones. Don't miss cleaning them .....Has anyone used fender covers? We have white fenders and the aluminum toons are making them black.
Yes those are the clips that we have they will fit but we dont jam them down because our kids put the fenders out and pull them in. We love them save a ton of time and dont have to re adjust them every time you get them out.Has anyone ever tried the "Fender Adjusters for Pontoon Boat Rails, 4 Pack" as noted in the website below:
(You may have to cut and paste the web address because I don't yet know how to make the web address send you directly to the web site like ABYPFCS correctly did earlier.)
http://www.overtons.com/modperl/product/details.cgi?pdesc=Fender-Adjusters-For-Pontoon-Boat-Rails-4-pack&i=74625&aID=602B2&merchID=4006
Supposedly, the plastic clip "clips" onto the aluminum pontoon rails and is easy to move about. I read that the plastic can break if too much stress is placed upon it though. Anyway, I would like to know it such a clip can be placed on the bow aluminum pontoon railing in a way that the inner edge of the clip can be slid between the bow pontoon railing and the upholstery without damaging the upholstery and still be used just as easily as when placing the clip onto the stern pontoon railing.
1. They are very easy to move around anywhere you may want it and very easy to adjust the fender height.1. Supposedly, the plastic clip "clips" onto the aluminum pontoon rails and is easy to move about.
2. I read that the plastic can break if too much stress is placed upon it though.
3. Anyway, I would like to know it such a clip can be placed on the bow aluminum pontoon railing in a way that the inner edge of the clip can be slid between the bow pontoon railing and the upholstery without damaging the upholstery and still be used just as easily as when placing the clip onto the stern pontoon railing.
Use blue Loctite, no problem with loose screws or removing them if needed.And do the screws hold fast to the aluminum rails and not slowly work their way loose?
