Well, I finally got to get my 2375 RCW on the water, I love how it drives, nice and smooth and plenty of power. Here is what happened on first WOT:
After 10 minutes of just cruising, I opened it up to WOT and started trimming up some, watching my RPM's. I only have analog gauge that I could find, so I don't have exact numbers. I noticed I got up to around 6500 (I know over what it should be), the boat then when into a deceleration mode of types and I got the "High Temperature Alarm"
Everything was good after that, I looked at my temp when I slowed down and it came to about 150F, no idea what it got to. I decided a while later to go WOT again and I watched my RPM's and kept them at no more than about 6400 with my trim. Boat ran great and never had the issue again all day.
With about 3/4 of a tank of gas, 2 people a dog and normal loading I got the boat to 50.3 MPH on my GPS, that is while limiting my RPM's. I figured I need a larger prop, I have an Enertia 17P on it now, so the next step is a 19P.
The dealer service department is telling me if I go to a 19P prop, I will lose about 500 RPM? I thought I would lose about 300 RPM which would be about perfect.
Any suggestions or thought?
On a side note, I had them raise the engine 1 hole, they did not want to do this and usually ship them out the door with the Engine all the way down. I did check out my anti-ventilation plate at cruise speed and I looked to be right on the water line, so it is not to high up as far as I am concerned. Of course the dealer went right back to this when I was talking to them about my RPM's.
Thanks
Scott
Thanks
Scott
