Safety.On a normal ignition, OFF means ALL switches are off. ACC means you can turn on lights, radio, etc. without starting the motor. Why are all my switches live when the switch is in the OFF position?
Jack, flip the helm master power switch on and see if everything still works. Sounds like a simple wiring fix. Don't let it get you down. It can and will be fixed. Probably something simple to fix under the helm.My switch does not work at all .Everything works without a key .
The only thing I need a key for is to start the motor.
Not Happy at this time .
I do shut down the master switch .I don't under stand why it is different from one year or model to the nextJack, flip the helm master power switch on and see if everything still works. Sounds like a simple wiring fix. Don't let it get you down. It can and will be fixed. Probably something simple to fix under the helm.
Unfortunately ,my Kill switch doesn't work either .DavidW,
You can always trip the kill switch to prevent someone from turning on the key or take the key out...you can still run your accessories.
You know, the really sad part of all this is that it appears to be indicative of a larger problem. Particularly if he's seeing this in other deliveries. Quality control and attention to detail are the two big things that in my mind have set Bennington apart from rest of the pack. There's really no excuse for some of the troubles that you're having with your boat. And, to be honest, your dealer should have caught most of this before the boat went out his door.My dealer is past the point of embarrassment .He is mad now .
Besides me, he has had delivery issues with others too .
