LIST YOUR SPECS HERE
tref
TREF's BOAT:
  • Boat Model --------- 2075 GS
  • Model Year --------- 2012
  • Tube Option -------- EPS center tube and wave shield
  • Power Option ----- Yamaha 150hp - 4-Stroke
  • Prop Specs ---------- TBD
  • Performance ------ 36mph but did not try seriously yet
Truthinthedetails
TRUTH's BOAT:
  • Boat Model --------- 2575 RCW
  • Model Year --------- 2011
  • Tube Option -------- Tri-toon w/ESP
  • Power Option ----- Yamaha 250 VMax SHO
  • Prop Specs ---------- 3 Blade Stainless steel Mercury Mirage Plus 17 pitch
  • Performance ------ 42mph @ 6,000rpm
Ken H
Venus, Texas
KEN's BOAT:
  • Boat Model --------- 2075 SLi
  • Model Year --------- 2009
  • Tube Option -------- Two 25" tubes
  • Power Option ----- Yamaha 90hp - 4-Stroke
  • Prop Specs ---------- 3 BladeMichigan Wheel 13.75 x 15
  • Performance ------ 26mph GPS @ 5700 rpm Glass smooth lake, no wind and just me in the boat.
gerry
GERRY's BOAT:
  • Tube Option -------- ESP w/center fuel tank & storage
  • Power Option ----- Honda 225hp - 4-Stroke
  • Prop Specs ---------- 3 Blade SS Mercury Enertia 14.75 - 16p
  • Performance ------ 42 MPH @ 6,000 RPM
Note: 2/3 fuel, 3 persons onboard, fairly choppy. After motor is completely broke in going to try an Enertia 15-15p.
RiverBill
Canyon Lake Calif.
RIVER BILL's BOATS:
  • Boat Model --------- 2275 3RL I/O
  • Model Year --------- 2006
  • Tube Option -------- Tri-toon Standard Performance Package w/Lifting Strakes all 3 Tubes
  • Power Option ----- 5.0L Volvo Penta SX Drive
  • Performance ------ 47mph @ 4,900rpm on GPS - Early Morning, smooth water, Parker Strip, one person, 1/2 tank fuel(approx 30 gal)
  • Boat Model --------- 22 SSI
  • Tube Option -------- Tri-toon XL Performance Package w/Lifting Strakes all 3 Tubes, 31 gallon rear fuel tank Pod
  • Power Option ----- Mercury 150 4 Stroke
  • Prop Specs ---------- Mercury SS Enertia 15X15p
  • Performance ------ 40 MPH (GPS) 6 Adults 3/4 fuel 5200 rpm Mid-day 105* Parker Strip Az. rough water light wind
Straydog
STRAYDOG's BOAT:
  • Boat Model --------- 2275 RCW
  • Power Option ----- Evinrude 250 HO - Two Stroke
  • Performance ------ TBD
Mudbug
Texas
MUDBUG's BOAT:
  • Boat Model --------- 2075 GFI
  • Tube Option -------- Two 25" Tubes w/o Strakes
  • Power Option ----- Yamaha TLR 90 - 4-Stroke
  • Prop Specs ---------- 3 Blade Stainless Steel - 13.25 x 13
  • Performance ------ 26 mph @ 5500rpm on GPS
Angela & Michael
Delaware
MICHAEL's BOAT:
  • Boat Model --------- 2275 GCW
  • Tube Option -------- Twin 25" Tubes
  • Power Option ----- Evinrude Etec 115 HO
  • Prop Specs ---------- 3 Blade Aluminum 3.75 x 13
  • Performance ------ Speed 28 MPH at 5750 RPM
EXTRA NOTES: Tested at half tank of fuel, 1 adults, all gear on board. Boat has 3 coats of Bottom Paint.
6-14-12 Adding SS prop this weekend. New results to follow.
Prop is on and now running 5700 & 28 mph
Better hole shot and some build up on the toons has held back any speed pickup.
Prop is Solas Saturn
13.75 x 13
birdieman
BIRDIEMAN's BOAT:
  • Boat Model --------- 2250 RCL
  • Tube Option -------- ESP Package
  • Power Option ----- Evinrude Etec 250 HO
  • Prop Specs ---------- 19P Rebel s/s
  • Performance ------ 46.5 GPS 5150 RPM
EXTRA NOTES:
Slow Ride
Charles City , Va
SLOWRIDES's BOAT:
  • Boat Model --------- 2574 GCW
  • Tube Option -------- ESP Package with Wave Shield
  • Power Option ----- Yamaha 250hp - 4-Stroke
  • Prop Specs ---------- Yamaha Salt Water Series 15X15.5
  • Performance ------ 42mph @ 6000rpm
EXTRA NOTES: One person, 1/2 tank of fuel, 50% on the trim gauge, air temp. 75, 3000 rpms 19 mph, 4000 26 mph, 5000 rpms 35 6000 rpms 42. Trimmed to 75% speed increase to 44.6 mph. Propeller slips a little in a turn, mostly between 3200 and 3800 rpms. Boat rides better than I expected.
cwag911
CWAG's BOAT:
  • Boat Model --------- 2275 RL
  • Model Year --------- 2007
  • Tube Option -------- 3 Logs with Lifting Strakes
  • Power Option ----- Honda 150hp
  • Prop Specs ---------- Enertia 15X15p
  • Performance ------ 38.9mph @ 6000rpm
EXTRA NOTES: Speed test done with full 36 gallon tank.
Fyrfightr
FYRFIGHTR's BOAT:
  • Tube Option -------- 2 Elliptical Pontoons with Lifting Strakes
  • Power Option ----- Mercury 115hp 4-Stroke
  • Prop Specs ---------- 14x13p Mercury Aluminum w/ Extra Cup
  • Performance ------ 28.4mph @ 6000rpm
EXTRA NOTES: Full tank of fuel, approx 700lbs of passengers on board. Trim almost 1/2 way on gauge. Could feel toons come out of water and "Dance" on top
LT1GMC
Indiana
LT1GMC's BOAT:
  • Boat Model --------- 2574GLi
  • Power Option ----- 250 Mercury Verado Pro
  • Prop Specs ---------- Enertia 14.50Dia x 17"pitch
  • Performance ------ 51.0 mph @ 6360rpm on GPS (2 adults on board)
KC_Steve
Olathe, KS
KC STEVE's BOAT:
  • Boat Model --------- 2275RCW Limited
  • Power Option ----- Yamaha F150
  • Prop Specs ---------- SS Apollo
  • Performance ------ 33mph @ 5800rpm (Off Dash Mount Speedometer)
EXTRA NOTES: The was with 2 passengers, 1/2 tank of fuel, 35 mph cross wind gusts, the bimini up, and trimmed up to the first black line on the gauge.) All in all, not ideal conditions. I will try again this weekend, and see what I can get.
Geoffrey & Brenda
Lawrence Kansas
GEOFFREY and BRENDA's BOAT:
  • Boat Model --------- 20 SLi
  • Power Option ----- Yamaha T50TLR
  • Prop Specs ---------- MW Vortex 14"x 13p
  • Performance ------ 18mph @ 5400rpm on GPS
EXTRA NOTES: 2 passengers, 3/4 tank, calm waters, bimini up. This was last summer. Also, I have just completed underskinning, and minor modification to the engine, it will be another week or so before i get to try her out again.
Hickory Sticks
HICKORY STICK's BOAT:
  • Boat Model --------- 22 SLi Extended Deck
  • Power Option ----- Mercury 60hp Bigfoot
  • Prop Specs ---------- 14"x 10p
  • Performance ------ 18-19mph @ 6100rpm on GPS
Update: New Prop 14"x 11p 21mph @ 5850rpm on GPS
Smooth water, light wind, 1/2 Tank of fuel, 2 on board + the wonder dog.
Dan's Benny
Forest, VA
DAN's BOAT:
  • Boat Model --------- 2275 FSi
  • Tube Option -------- Two 25" Tubes without Strakes and Express tube with Strakes.
  • Power Option ----- Yamaha F115
  • Prop Specs ---------- 15" x 13p Mercury aluminum
  • Performance ------ 28mph @ 5800rpm on GPS
Jim_R
Jim_R's BOAT:
  • Model Year --------- 2002
  • Power Option ----- 2006 Mercury 115HP EFI 4 stroke
  • Prop Specs ---------- 3 Blade Aluminum Mercury H 14 x 13 pitch
  • Performance ------ 23 mph @ 5200rpm on GPS - Early Morning, smooth water, two people, 1/2 tank fuel(approx 16G). Double biminis in boots and upright positions. Toons not clean.
Extra Notes: GPS momentarily reported 26.6 mph, but I don't believe it.
Willb
Logans Landing @ Indian Lake Ohio
WILL B's BOAT:
  • Boat Model --------- 2575 RCW LTD
  • Tube Option -------- ESP Performance Strakes and shield
  • Power Option ----- 2012 Mercury Verado 250
  • Prop Specs ---------- 3 Blade Mercury Enertia 15
  • Performance ------ 46 mph @ 6300rpm on GPS - choppy water, one adult two children, 2/3 tank fuel(approx 40G).
Extra Notes: Motor climbs to full rpm very quickly.
June 25th update 4 weeks of being in water couldn't break 40 with two adults. Sand bar cleaning day here I come
Randy@LKN
RANDY's BOAT:
  • Tube Option -------- Twin Tubes, Standard with Forward Strakes.
  • Power Option ----- Yamaha 150hp 4 Stroke with Power Assisted Steering
  • Performance ------ 32 mph @ 5200rpm on GPS
