LIST YOUR SPECS HERE
ericscher
Buckeye Lake, Ohio
We're starting this thread to collect everyone's specs in one place. That way, anyone wanting to know how the different options will affect their own boat just can look in one spot to see everyone else's real world experiences.
Just hit the reply button to this post, which quotes the format, and edit it to fit your specs. Simple and easy.
Make sure you get in the small details like the size of your pontoons, do they have strakes, the brand, model name and HP; that sort of thing. If you happen to have a specialized option like the ESP or Dual Elliptical setup, or perhaps are running a jack plate, mention that too.
Oh, almost forgot... Let's try and keep this thread "single purpose". If you are reading the thread and realize you have a particular comment or question for someone in regards to their specs & numbers, just start a thread in the forum and make sure to include the person's Online Name in the thread title so that they know you wanted to ask them something.
That's about it. Have at it! B)
ERIC's BOAT:
  • Boat Model --------- Sedona L21
  • Model Year --------- 2006
  • Tube Option -------- Two 23" Tubes w/o Strakes
  • Power Option ----- Yamaha T50 - 50hp - 4-Stroke
  • Prop Specs ---------- 3 Blade Aluminum - 14x9p
  • Performance ------ 18mph @ 6000rpm on GPS
spinzone
Marvin, NC
SPIN's BOAT:
  • Boat Model --------- 2275 RCW
  • Model Year --------- 2011
  • Tube Option -------- Two 25" Tubes w/o Strakes
  • Power Option ----- Mercury 115hp 4-Stroke model
  • Prop Specs ---------- 3 Blade Aluminum - 14x13p
  • Performance ------ 26mph @ 6300rpm on GPS
    Update 04.13.12 - with polished tubes, ran 29mph on 3/4 tank of fuel, 1 person, and bimini down.
Toonafish
TOONA's BOAT:
  • Boat Model --------- 24 SF
  • Model Year--------- 2012
  • Tube Option --------- Two 25" w/o Strakes
  • Power Option ----- Mercury 75hp 4-Stroke
  • Prop Specs ---------- 3 Blade Aluminum 14x13P
  • Performance ------ 22 MPH @ 6000 on GPS
Friar
FRIAR's BOAT:
  • Boat Model --------- 2275 GFI custom
  • Model Year --------- 2010
  • Tube Option -------- Two 32" Ellipticals w/o Strakes
  • Power Option ----- Yamaha F90 - 90hp - 4-Stroke
  • Prop Specs ---------- 3 Blade Aluminum - 13-5/8 x 13p
  • Performance ------ 25mph @ 5900rpm on GPS
Mary Lou
Lees Ford Lake Cumberland
MARY LOU's BOAT:
  • Boat Model --------- 2275 RFSI
  • Model Year --------- 2008
  • Tube Option -------- Three 25" w/ Strakes
  • Power Option ----- Yamaha F150- 150hp - 4-Stroke
  • Prop Specs ---------- 3 Blade Stainless 14.5 x15
  • Performance ------ 38mph @ 6000rpm on GPS
mtudb24
MUDB24's BOAT:
  • Tube Option -------- Twin 32" Elipticals with sealed lifting strakes on both inside and outside strakes
  • Power Option ----- Mercuy Optimax Pro XS 150hp (165hp actual - Factory Underrating)
  • Prop Specs ---------- 3 Blade Stainless 15x15p Mercury Enertia
  • Performance ------ 44mph @ 5700pm on GPS. Light load. Typical load 41-42mph 5500-5600
qapd
Texas
QAPD's BOAT:
  • Boat Model --------- 2275 SFI
  • Tube Option -------- Twin 25" Tubes
  • Power Option ----- Yamaha 90hp Four Stroke
  • Prop Specs ---------- 3 Blade Stainless 13x14.5p Power Tech
  • Performance ------ 24 mph @ 5200rpm by gps
Wild and Free
Lake Sakakawea & Missouri river Of ND
WILD AND FREE's BOAT: (Prior Boat)
  • Boat Model --------- 2275 GL
  • Model Year --------- 2007
  • Tube Option -------- Three 25 inch tubes with strakes on both sides of all 3 tubes & 20" transom
  • Power Option ----- Yamaha F150 TLR Four Stroke
  • Prop Specs ---------- 3 Blade black Stainless 15.25 X 15p yamaha prop
  • Performance ------ 41mph @ 5900rpm on GPS
EXTRA NOTES: Full tank of fuel "35 gallons" 2 people and daily gear. 5800 rpm 38 mph, half tank fuel or less 5900+ rpms and 41 mph GPS Checked at approx. 2200 elevation and 80*f average.
WILD AND FREE's BOAT: (Current Boat)
  • Boat Model --------- 2250 GCW
  • Tube Option -------- ESP with rough water package wave shield & 20" transom
  • Power Option ----- Yamaha F150 TLR Four Stroke (2007)
  • Prop Specs ---------- 3 Blade black Stainless 15.25 X 15p Yamaha prop
  • Performance ------ 38mph @ 5500rpm on GPS
EXTRA NOTES: Full tank of fuel "60 gallons" 2 people and daily gear. 5400 rpm 36 mph, half tank fuel or less 5500 rpms and 38 mph GPS Checked at approx. 2200 elevation and 80*f average.
Prop change (Yamaha Reliance 14.5x15p) and new performance numbers pending for next season.
EricZ5
Lake Wallenpaupack, PA
ERIC Z5's BOAT:
  • Boat Model --------- 2575 RCW Limited
  • Model Year --------- 2012
  • Tube Option -------- Two 32" Elliptical Tubes w/ Sealed Lifting Strakes, Rough Water Package, Underdeck Wave Shield
  • Prop Specs ---------- 3 Blade Yamaha Saltwater Series II 19x15.25p
  • Performance ------ Info pending maiden voyage
kaydano
KAYDANO's BOAT:
  • Boat Model --------- 24 SSL
  • Tube Option -------- Express Tube Package with strakes on both sides of all 3 tubes
  • Motor #1: Mercury 115 HP Four Stroke (2012)
  • Prop #1: 3 Blade Mercury Black Max 13.75 X 15p..... 35mph @ 6400rpm on GPS
  • Prop #2: 13.8 x 13p Mercury Spitfire (Pontoon Series)..... 32 mph @ 6400 rpm on GPS.
  • Comments: The Spitfire is a tad slower top end, but the lower pitch is incredible on acceleration and gives significantly better tubing performance, although not enough to keep me from trading in the 115 for a 150.
  • Motor #2: Mercury 150 HP Fourstroke (2013)
  • Prop #3: Mercury Black Max 15 x 15 (aluminum)..... 41 MPH, 5800 RPM with light load (just me, full tank).
  • Prop #4: Mercury Enertia 15 x 15 (stainless steel)..... 42 MPH, 5800 RPM with light load (just me, full tank). 39 MPH at 5700 RPM with 8-9 passengers, full tank of gas, and full gear (coolers, anchors, etc).
  • Comments: After lots of driving with both props, the Black Max is only about 1 MPH slower than the Enertia at the top end. I got 42 MPH on GPS with the Enertia for just a few seconds today, but 99% of the time I get 41 MPH on the GPS. I hit 41 MPH with the Black Max, but much of the time it maxed out at 40 MPH. The difference between the two is holding power. The Black Max was VERY touchy and just the slightest amount of trim would cause it to ventilate in turns at practically any speed. The Enertia is like night and day when it comes to handling. It does not ventilate until I've trimmed up substantially more. This is a big deal when you are pulling tubes, as having a delicate touch on the trim is just one more thing to worry about with the Black Max. Dollar for dollar, the Black Max is very impressive on top speed. The Enertia really shines in handling though. The only way I'd put the Black Max back on my boat is if the Enertia got wrecked somehow.
  • Comments on the 150 vs the 115: If you plan to give exciting rides when pulling a tube, you will not be impressed by the 115. It is just not enough motor. The 150 does all that I ask of it. One thing I found interesting is at any given mph, the 150 actually used LESS gas than my 115 did. Another interesting thing, and perhaps the biggest difference between the two motors is the 115 REALLY bogs down with just a few people in the boat. With the 115, when pulling a tube with a half full boat of people my top speed would drop nearly in half, especially in turns. With 7 or 8 people on board, I was lucky to hold 16 MPH in a turn pulling a tube with the 115. The 150 on the other hand only dropped a couple MPH in top speed with 7 or 8 people on the boat. I don't know how it does this, but it is amazing. As far as tubing with the 150, lets just say I never go full throttle with it. However, with the 115 it was pretty much full throttle all the time when tubing. Looking at the specs, the 150 is only 35 HP more, which doesn't seem like much on paper. But in real-world use, the 150 is like having two 115s hanging off the back of the boat.
RedRaiderTooner
REDRAIDERTOONER's BOAT: (Current Boat
  • Boat Model --------- 22 SLi
  • Tube Option -------- 2 32' Elliptical Tubes - no strakes
  • Power Option ----- Yamaha F115TLR Four Stroke
  • Prop Specs ----------3 Blade Apollo Michigan Wheel Stainless 13.375 X 15p
  • Performance ------ 28mph @ 5700rpm on GPS
EXTRA NOTES: 28 mph, 2 people, half a tank and bimini down at 5700 RPM's. 24 mph, 4 adults, half a tank, bimini up 5500 RPM's. Looking at a smaller pitch Yamaha Pontoon Performance prop in the Spring to get a few more RPM's.
Butchkid
Flower Mound, Tx
Butchkid's BOAT:
  • Boat Model --------- 2575 QCW I/O Tri Toon
  • Tube Option -------- High Performance Package: 32" Elliptical Center Pontoon with Lifting Strakes and Underdeck Wave Shield
  • Power Option -------Mercruiser 350 MAG 300 HP MPI
  • Prop Specs ---------Twin contra-rotating stainless steel 3 blade props 15.5 x 24p Front, 14.25 x 24p Rear
  • Performance ------- 46mph @ 5000
WoodenPontoon
WOODENPONTOON's BOAT: (All Spruced Up
  • Boat Model --------- 22 1/2' All Wooden Custom-Handcrafted Tri-Hull
  • Model Year --------- 2009
  • Tube Option -------- 24" Diameter U-Shaped Tubes No Strakes (yet)
  • Power Option ----- Remanufactured 1985 Evinrude 90 HP 2-Stroke
  • Prop Specs ----------3 Blade Aluminum Prop
  • Performance ------ Will be determined after Tach is connected
EXTRA NOTES: Bennington Furniture, carpet and bimini.
drago
DRAGO's BOAT:
  • Boat Model --------- 2577 RFSi
  • Tube Option -------- 25" Triple Tube w/six 6" strakes
  • Power Option ----- Yamaha F225 4 stroke
  • Prop Specs ----------3 Blade 14.25 x 17p Stainless Solas
  • Performance ------ 43mph @ 6200rpm
EXTRA NOTES: This boat turns flat and has no cavitation unlike the JC Tritoon, Premier PTX, Bennington ESP, and others with big center tube when pulling loaded Big Mable. Towable.
Fasttr
Rockwall, TX
Fasttr's Bennington
  • Boat Model --------- 22 SSi
  • Tube Option -------- Twin 25" Tubes w/o Strakes
  • Power Option ----- Yamaha T90 - 90hp - 4-Stroke
  • Prop Specs ---------- 3 Blade Aluminum - 13.375 x 14p
  • Performance ------ 23mph @ 5800 rpm on GPS
My Testing
gaztro
BARRY's BOAT:
  • Boat Model --------- 22 SSLX
  • Tube Option -------- Twin 25 rounds No strakes
  • Power Option ----- Yamaha 115hp 4 stroke
  • Prop Specs ----------Stock (Specs Unknown)
  • Performance ------ 31mph @ 6200rpm
EXTRA NOTES: 2 on board 3/4 fuel tank
StevL
StevL's Boat:
  • Boat Model --------- 2275 GCW
  • Tube Option -------- Twin 25" Tubes, very clean (like new)
  • Power Option ------- Yamaha 115hp Four Stroke (F115LA)
  • Tested at 3/4 tank of fuel, two adults, all gear on board.
  • Prop A Specs --------- 3 Blade Solas Amita 3 Aluminum 13.5 x 15 GPS @ 26.9mph, 5200 RPM
  • Prop B Specs --------- 3 Blade Yamaha Aluminum 13.5 x 15 GPS @ 27.4mph, 5900 RPM
Interesting, same pitch and diameter props, two different blade designs that operate in a completely different RPM range.
JasonLepore
South Jersey
JASON's BOAT:
  • Boat Model --------- 2254 STI
  • Tube Option -------- 3 Full Length 25" Tubes w/ Strakes on the Center Tube
  • Power Option ----- Yamaha 150hp - 4-Stroke
  • Prop Specs ---------- TBD
  • Performance ------ Info pending GPS test.
liljake83
LAKE OROVILLE CA
LILJAKES's BOAT:
  • Boat Model --------- 22 SLX
  • Tube Option -------- Express package with strakes on center toon and inside of outside tunes
  • Power Option ----- Mercury 150hp - 4-Stroke
  • Prop Specs ---------- Mercury Enertia 14.5 x 17p Stainless
  • Performance ------ 42 mph @ 5500rpm on GPS
Smoky Mountain
SMOKEY MOUNTAIN's BOAT:
  • Boat Model --------- 2274 GL
  • Tube Option -------- Tri 25" with Express Performance Package includes modified
    center tube and wave shield PN904337
  • Power Option ----- Yamaha F150LA - 4-Stroke
  • Prop Specs ---------- 15 1/4 X 15 Aluminum
  • Performance ------ 30 mph @ 5000 RPM, Garmin GPS two persons, 25 gallons fuel. Light wiind, light chop tops down.
    35 mph @ 5400 that's all there is with this prop. Top RPM is supposed to be 56-5800.
