Looking for a little help on a new to me 2011 2275RCW.
1) Has anyone ever removed the door between the loungers? There is sill a chain at the rear however I can see wanting to access the rear lounges while underway and the door will just be a nuisance. If anyone has removed the door what did you do with the area where the hinges are mounted to the side of the loungers?
2) The horn on the boat is not working and I have looked everywhere for it, anyone know where it is?
3) The side door was never used on this boat and the bow gate seat was placed on the port side where the gate is. I now want to put the bow gate seat back in the bow. The problem is the gate door won't open and close very well. I tried WD40 and working it up and down and nothing. I was unbolt it from the fence and bring it into the house to work on it but its riveted in. It does not appear to be rusted or bent. hoping there is some fix I am over looking.
4) I have a Sony Stereo with the remote on the dash. what is needed to hook up a IPod? I am thinking I want to run a wire thru the drain hole to the location opposite the GPS on the dash and have the IPod there, anyone done that?
5) There are 2 USB connections under the dash, one is a male and one is a female. If I trace them they appear to go to a bundle of wires directly under the GPS. Any idea what they are for? Should I plug them into each other? GPS powers up but I have not had a chance to see if it works properly.
Thank you in advance for your help.
Brian
Still looking for a granite cooler table if anyone has one they want to part with
Brian
