Welcome to Club Bennington
Login Register
Porpoising
Discussion in 'Members Zone: Props and Power' started by mbhenry1955, Jan 20, 2018.
  1. mbhenry1955
    mbhenry1955 Well-Known Member
    196
    49
    Cincinnati, Ohio
    I have a 2250 ESP with a Honda 250 mounted 1 hole up and turning a 14x21 Enertia prop. At WOT and trimmed up fairly high but still within my WOT RPM range my boat will porpoise.
    Will raising the engine up 1 more hole help control the porpoising?
    Thanks
    Mike
  2. cwag911
    cwag911 Moderator
    5,153
    1,271
    Porpoising happens when you are over trimmed as far as I know. I don't think motor height will change it.
  3. Michiman
    Michiman Well-Known Member
    1,293
    636
    Okemos, MI
    I'm with Carl on that. If I over-trim I can get the same effect.
    Vikingstaff and mbhenry1955 like this.
  4. adkboater
    adkboater Well-Known Member
    865
    565
    Tylersport,Pa
    Ditto....... too much trim would be the issue, raising the motor another hole might help your rpm/top end but won’t stop the porpoising.
  5. mattb
    mattb Well-Known Member
    585
    455
    Central Ohio
    I trim up til that starts, then just bump it back down a bit til you find your happy spot. Funny thing is, it seems I can eek out a little more speed with just a little porpoise.
    Vikingstaff likes this.
  6. mbhenry1955
    196
    49
    Cincinnati, Ohio
    I have found that out also!
  7. JTaylor
    JTaylor Well-Known Member
    569
    181
    Woodbridge, VA
    Yep, me too. Then the "slow down" voice warning gets activated from the seat next to me.
  8. mattb
    585
    455
    Central Ohio
    You missed the mute button option on the order form didn't you.
  9. royal4
    royal4 Well-Known Member
    212
    108
    Jordan Lake, NC
    HA, never works.... I've found when you try and activate the mute function it just gets louder.
    mattb, adkboater, Bork and 3 others like this.
  10. BigKahuna
    BigKahuna Well-Known Member
    3,079
    1,226
    North Carolina
    Even if you had the mute button option ........the built in Mute Over ride button will kick in!!!
    lakeliving, mattb and adkboater like this.
  11. Havasu
    Havasu Well-Known Member
    544
    293
    Lake Havasu City, Arizona
    That's pretty much what I did to find the "sweet spot." After extensive testing in all sorts of conditions, I've found if I just trim it 3 bars up from the bottom position I can leave it there all day. Works fine whether I'm cruising, WOT or pulling a skier/wakeboarder or tuber. I'll bring it up of course if I'm beaching in shallow water. I don't see a big difference in fuel economy and I don't have to keep messing with the trim all day. It's takes some experimentation and every boat is different so it will take a few outings until you easily see where you should run it. I think we've all gone through this transition.
    Michiman and adkboater like this.
  12. lakeliving
    lakeliving Well-Known Member
    6,735
    3,194
    Palm City Florida
    My boat is very sensitive to trim in the sense I can trim it up quite a bit before blowout. I noticed this fall with a light load and really trimming up I was going over 6k rpm. I want to say 6200ish. Something I’ll look at again when I put it back in the water soon.
    Link and mbhenry1955 like this.
  13. Michiman
    1,293
    636
    Okemos, MI
    Yeah, just rub it in. :)
  14. lakeliving
    6,735
    3,194
    Palm City Florida
    It won't be until March before it gets wet. Might as well still be in MI!
  15. BigKahuna
    3,079
    1,226
    North Carolina
    Well you've got a lot of other things to take care of in the mean time.......Getting settled at your new job, preparing to move in to that beautiful home, tying up loose ends in Michigan, etc etc. You'll have plenty of time for boating later......
    adkboater and lakeliving like this.
  16. Link
    Link Moderator
    4,630
    1,689
    Sacandaga Lake, NY
    Why? you want to be shoveling snow in March ;)
  17. lakeliving
    6,735
    3,194
    Palm City Florida
    The seasons don't bother me. I enjoyed snow, just not months and months of it. There is nothing like that first decent winter snow before Christmas. I'll miss that. Maybe that will change though!
    adkboater and cwag911 like this.
Share This Page
