Ski Pylon
Spoiledrotten
Below the Mason/Dickson Line
Hi Mike , yes I had it made for less then $100. It is 53" and made from solid 3" aluminum. I had the local technical college machine the groove in the end for the rope and tap the other end for a 3/4" stud. I used a 3/4" X 4" stainless steel stud for the hole in the tunnel. I then put I believe a 2 1/2" X 3/8" angle bracket across the top of the tunnel and inline with the ski pylon.
When are we going to see the pics of this work?
toddkru
Cant wait for the pics! We bought an SX last summer and I was just quoted $1091.49 for the bar. That is crazy! I will be shopping for a 3" piece of stock in the meantime. Please include the bracket pics!
East Texas
Hi Mike , yes I had it made for less then $100. It is 53" and made from solid 3" aluminum. I had the local technical college machine the groove in the end for the rope and tap the other end for a 3/4" stud. I used a 3/4" X 4" stainless steel stud for the hole in the tunnel. I then put I believe a 2 1/2" X 3/8" angle bracket across the top of the tunnel and inline with the ski pylon. I bolted it thru the top of the tunnel and then I made a U clamp out of stainless threaded rod and used it to attach the pylon to the angle bracket. I used this instead of the aluminum plate shown in the pictures. Hope this helps.
Sounds like you have this down pretty good do you have any pics u can share?
