donmartin
I busted the bracket on my Garmin transducer which the only fix is to replace it. I have the replacement. I know the best option is to home run the sealed cable all the way back to the Echo 100 in the dash. I've looked at how the original cable is routed which appears to be on top of the port toon and then cutting across about midway under the floor to the console. I could probably get the toon part done but have no idea how to get it under the floor without tearing the boat apart.
I'm also considering cutting the existing cable, soldering it then shrink wrapping it but wondering if that will cause issues. Any recommendations?
