Quick question, my bennington had a leak in the pontoon so i took it to my dealer. They identified the leak as a bad weld on the top of the pontoon which was covered by warranty, to fix this they:
A. Drilled a hole in the back of the pontoon to drain the water and filled the hole with epoxy
B. covered the leaking weld with epoxy
Has anyone ever had this done? Does this seem like an appropriate way to fix a bad weld?
