Tooncrazy
I have a 2275 GCW Yamaha F115LB build pending for this month. I'm trying to decide whether to add the EPP option or not. I can't justify the other middle pontoon options.
Will I regret going the EPP route with a Yamaha F115LBA? The main negative seems to be excessive bow lift with the EPP setup, how bad is it actually? The plus seems to be a nicer over all ride once on plane? Could I also get a speed increase with the EPP option?
Thank you.
Thank you.
