walleye man
- Messages
- 6
- Reaction score
- 0
just orderd a 24 sfx with a 150 mercury with exprees package
i was wondering how fast the pontoon will go.
i did not knoww you could get a 150 on a 22sslWalleye Man,
Per the Mercury Owner's Manual Engine Break-in procedures you are allowed 1 minute full throttle operation for every 10 minutes of operation during the first 2 hours of break-in and up to 5 minutes full throttle for the next 8 hours of break-in. So you should find out quickly if the boat is has the right prop. Our Mercury 150 has a mercury SS prop w/15 inch pitch runs out at 5200 rpm.
Enjoy
RiverBill
Walleye Man,
I have the 2012 22 SSI Bennington 3 tube XL performance package with lifting strakes on all three tubes and the New Mercury 150 4 stroke motor. I'm still breaking it in, but I have it up to 40.0 mph (GPS) with 6 adults and 3/4 tank of fuel. Your boat is a little heavier and longer, I would guess you should run in the mid to high 30's.
Enjoy Your New Binnie!
RiverBill
Hi Bama, The twin elliptical tube package is an option for the 22 and 24 S models...TBI just came from the Bennington dealer @ Pickwick Lake, TN. this afternoon. He said that the elliptical twin toons are no longer available on the S model boats. If you want 150 hp, you've got to go the Express Package.
Maybe the retail market is demanding triple toon boats, and the XL and Express Packages are the substitutions.
Does anyone know about this?
Kaydano,
I don't know I ordered the boat at the end of March with the express tube package, the dealer came back to me after one week and said that there was a new 150 XL performance package that out performed the express package. Dealer sent me the specs on the XL package and I said let's go for it! No change in the boat price. I have a Bennington memo that shows all the specs for the XL packages. Listed below:
RiverBill
XL -150 PERFORMANCE PACKAGE
Unpublished as of January 26, 2012 (published package name TBA) 3/12/12
• 25” Transom
• Full length 25” center tube
• Lifting strakes on center tube
• Performance foils on inside of outer tubes
• Rounded keels on all 3 tubes
• Wave tamer (same as Express Package wave tamer)
BENEFITS
• Provides ESP-like performance and banking on lighter boats
• Planes at a lower speed than the Express Tube Package
• Better boat balance, stability, handling and reduced spray in the transom area over the Express
AVAILABILITY
This package is designed for models with 20’ & 22’ tubes. Applies to S-Series only. This package benefits lighter boats and is functional on heavier boats to a lesser degree. Transom structure is rated for 150hp or less
• 22 SL / SLX
• 24 SL / SLX
• 22 SF / SFX
• 24 SF / SFX
• 22 SSL / SSLX
• 24 SSL /SSLX
NOTES
• Hydraulic steering not forced but still highly recommended for engines with 115hp or greater
• Capacities are the same as Express Tube Package capacities
• 32 gallon in tube fuel tank (available in March) replaces pod tank. Models with above floor tanks do not change (S- misc. models)
• Does affect ski tow options. Boats with transom fuel get a all new ski tow bar (to be developed) extended aft deck will get the same bar as a non-XL-150
Is this package still availble i just ordered a 24sfx with express package and a merc 150 4 stroke. I asked the dealer if i could put a Merc 150 4 stroke on a 22sfx and he said that a 115hp was the highest you could put on the boat. I rather have the 22sfx with the 150 due to the fact it will manuver around better while fishing.
I got my 24 sfx a week ago and love it express pk strakes all 3 yubes.
The 150 mercury with a 15.1/8 x 14 prop 40 mph i changed the prop to 15x15 i get 43 mph both props work great mercury Enertia great prop.
Thats with four adults on board. Its earther more power or more speed.
walleyeman
