Jim_R
- Messages
- 442
- Reaction score
- 37
I'm with TomS, I like to keep house/ starting systems separate. Still, since you asked, here is how I would wire a Stereo/Everything Else two bank setup with the Add a Battery 7650. I left out the LED and ACR toggle switch which are relatively straightforward. BTW - the battery labels are wrong, the two that say House are really Stereo, and the single Start battery is really Starting and House systems (Everything else).
A three bank configuration with Starting/House/Stereo might be worth considering. Perhaps a second Group 27 for House systems, then separate out the two Group 31's and stereo as a stand alone system only tied in at the ground distribution block, and through another SI ACR 7610 (with a toggle switch on the negative connection). This way you have the 'standard' two bank Starting/House setup, each with it's own Group 27, and two devoted group 31 batteries to your stereo, that can be tied into the charging system at will. The combine function of the switch included with the add a battery package would only combine House and starting batteries, and not the dedicated stereo batteries. The only time you would want to use the toggle to turn on the second ACR supplying juice to the two stereo batteries is to top them off when the stereo is off, or playing at very low volume.
Hope you don't mind me helping you spend your money!
