1trotter
best price is on amazonThank you! I am going to look into that right now!
Curious, did you end up using this solution on your rails or find an alternative? I am considering a boat with a similar issue. Thanks!Thank you! I am going to look into that right now!
Surprisingly, a Magic Eraser got most of it out. I have just learned to live with the rest of it. Not to mention that I have added a few myself. It doesn't hurt as bad the first time you scratch it, if it isn't perfect to start with.Curious, did you end up using this solution on your rails or find an alternative? I am considering a boat with a similar issue. Thanks!
I looked into it, but it would require a whole new aluminum skirt to accommodate the rubber rail. There are a couple aftermarket options, but nothing that would look like if it came from factory. Figured it wasn't worth it and expect I will get another boat at some point that will 100% have it.You still have the option of adding a rub rail
