2275 GCW with F150XA a dog in corners when tubing
mrbsdad
When swinging a tube it just falls on its face
I have a 2013 2275GCW with a Yamaha F150XA
Prop is a yamaha reliance series 15-m 14 1/2
Have esp package with lifting strakes
qapd
Texas
I have the same problem with a 90hp.  Too much boat.
BulldogsCadillac
Just some guy
Dauphin, Manitoba
So you have the 3 full length tubes with the one in the centre being elliptical? Just double checking as there was some confusion before with a different member.
Jack M
Indian River ,Michigan
Unless its a bad pic I dont see a  center tube
BigKahuna
North Carolina
So it just bogs down when you are turning?!?
How many people do you have on the boat when you are tubing?!?
Is the outdrive trimmed up when you are turning?!?
mattb
Central Ohio
Mine will slow down also, while they are good performers there are limitations.  I tube around 20 mph or so with a teen/adult, when cornering, trim down and accelerate to carry speed.  If you pull wide open you have no choice but to be slowed down when turning, especially if it's a 180, it's slowing down.  I had to change my driving style from the old glass v hull.  Leave yourself some throttle for the turns.
Jack65K
Kimberling City, MO
Same as math, have to give a little more throttle in turns to maintain speed and ease off when straight.
Jack
mrbsdad
Only a pooch in sharp turns. Usually trimmed at 3/4. I have it 38 gps on straight shot with two adults and almost full tank. I was reading somewhere that a 13 pitch prop is better for water sports but you sacrafice top end.
1trotter
SOUTH CAROLINA
I bought a 4 blade turning point prop for water sports and it worked great on my previous boat which was similar to yours.   Much less prop blow out and  only lost 1 mph top end.
mrbsdad
I was reading about those but there were mixed reviews so that good to here. Some said it had a much better hole shot. Do you remember what size and pitch you had?
BigKahuna
North Carolina
While tubing, skiing, wakeboarding, etc. etc. Keep the trim all the way down.....
lakeliving
Trim down in tight turns. I could kill someone behind our boat on a tube!
mrbsdad
TejasNewbie - we went out again today and a buddy went with that had been out with me before and noticed a significant difference with it trimmed down. My oldest even asked me to slow it down when turning because it was hurting his arms trying to hold on during the sling shot
Bamaman
Florence, AL--Tennessee River
The truth is the ESP center toon adds substantial weight and has quite a bit of drag. It's worthy of far more engine than 150 hp. The fact that you're getting 38 mph means the engine height and prop is correct for general cruising. Dropping back to a 13 pitch prop would work better for water sports, but it'd cost you some top end speed.
