Chase way from the outboard to the console? NEMA 2000 install
cwrivera
Wondering if anyone installed a NEMA 2000 system on their bennington?
I see the control cables from my Yamaha outboard snake back to inside the console. Is there a chase way in between the floor joists? I'm thinking if I can snake through there I can pull the cable through? Thanks for everyone's help.
Hosstyle
I would also like to add the NEMA 2000 to my motor. What Sonar are you connecting to?
DaveyJ
Moorhead, MN
I installed a NMEA 2000 network on my boat and it's a pretty easy install. Since my the under-skin on my boat was removed for Sea Leg installation, I can't answer your question on the chaseway. Here's the link to my write up. Hope it helps....
SEMPERFI8387
York, Pa
Do you have underskinning? You could unbolt the outer trim cover and run the cable up through the m brackets if so.
