I ordered the power bimini and it only has the small trailering support post. When the bimini is raised in the up position with the boot on everything is fine. When you want to open the bimini and remove the boot there is no support bracket and the back to rails of the bimini fall down and crash on top of the back seats and whomever might be seated there. Does anyone else see this as a bad design? You need to have a support bracket that you can snap into place prior to removing the boot.
I have contracted the dealer thinking that my support bracket was missing and Bennington says the power bimini supposedly has none. Has anyone else had this problem?
Thanks.
Thanks.
