Welcome to Club Bennington
Login Register
Pulling Pontoon on Shore
Discussion in 'Pontoon Forum' started by SharkBate, Oct 3, 2017.
  1. SharkBate
    SharkBate New Member
    hi, 2 questions about pontoons:
    This is 1st winter for my pontoon and am trying to decide on winter storage options.
    I was thinking of pulling the boat onto shore for the winter. It is a sandy shore with about a 10% grade. Many of my neighbors use PVC pipes under the pontoons and a winch to pull it up. I was wondering if this is a good idea, and how much winch will I need for a boat that ways about 2k lb's.
    2nd separate question is weather a 10'x4' aluminum dock can be used for mooring. I'm worried that the boat might pull the dock off along with it in high winds. The lake is mostly calm with no more that 6" of swells, except for boat wakes.
    Thx.
  2. Spoiledrotten
    1,673
    1,377
    Below the Mason/Dickson Line
    Do you have a friend with a 4x4 and winch? Problem solved if you go with option one.
  3. bcpnick
    bcpnick Nick
    1,085
    673
    Salt Lake City
    How do they pull them back into the water come spring?
    Mike31406 likes this.
  4. Link
    Link Moderator
    4,751
    1,935
    Sacandaga Lake, NY
    I would imagine that the boat is well anchored and when the water rises in the spring it floats
    BigKahuna likes this.
  5. BigKahuna
    BigKahuna Well-Known Member
    3,271
    1,481
    North Carolina
    Welcome to the forum Sharkbate.........
    Assuming you have an outboard.........If you pull your boat on that sandy beach will the motor be able to be kept/stored in an upright position so it can properly drain the water so freezing wouldn't occur.
    Is the aluminum dock permanently fixed or floating?!?
  6. SharkBate
    Thanks for replys.
    * To put it back in water, just un-chock pipes and it will roll back by itself (I hope).
    * Boat has electric motor, so no worries about tilting or drainage.
    * Dock is fixed with auger legs. It has to come out for winter too.
    Thx.
  7. adkboater
    adkboater Well-Known Member
    1,144
    839
    Tylersport,Pa
    Sounds like reasonable ideas to me! I can’t answer about the dock but pulling in up on shore and rolling it back in should work fine, just make sure you buy heavy enough PVC otherwise it’ll crush under the load.
  8. SEMPERFI8387
    SEMPERFI8387 Moderator
    8,595
    2,846
    York, Pa
    I think you would have to have multiple loose pipes to place behind it as it's rolling back. Once you hit the fulcrum point, the rear of toon would drop so you have to keep placing pipes behind it as it rolls..... make sense??
Share This Page
