Polaris192
I need to get the toons cleaned up below the water line. The previous owner left the boat in the water for the season for about 10 years. There is heavy build up (1/16" +) of mineral deposits. Im hesitant to use an acid like CLR or the works toilet bowel cleaner. Are those fine or is wet sanding with a 220 grit a better option? If I do sand what type of sander, da or line sander? Also what grit do I use?
Thanks!
Tim
Thanks!
Tim
