DanielG
- Messages
- 65
- Reaction score
- 54
I used audio shop to upgrade my Kicker Head unit.
What head unit did you wind up choosing?
Search "installed power sub today". The speakers will be as easy as unhooking the wires behind them and unscrewing/screwing the new ones in there place. Because I have underskinning and my boat is either in rack storage or in the water, I thought it almost impossible to add a sub but Renagade34 posted what appears to be an easy solution (at least for my set up and abilities). Good luck!Michiman, thanks! I don't know much about the stereo stuff but the speaker change out seems simple enough. Mine are under the seat so that seems pretty easy. I'm hoping that Kicker KMC2 has a way to add a Subwoofer easily. I like plug-n-play. lol I'm going to do the search for Subs as suggested. I'll also inquire with the dealer about the power assisted steering. This forum is going to be very helpful.
The problem with adding the sub directly to the KMC2 is getting the wires there. If you don't have the underskinning, it's certainly easier. I'm going to mount my powered sub close to the battery under the stern lounger and then splice into the port stern speaker wire to pick up the signal. Thus, I no longer have to run wires (power, ground, etc.) 18 to 20' or more. Make sense?I read that thread. Sounds easy, which is my first mistake normally, but after looking at the wiring diagram online for the back of the KMC2 it looks as if I can add the Sub pretty easily. Speakers should be even easier. Thanks.
I have the blackout and floor storage. You will regret the floor storage more than the blackout. Holds so much stuff I'm not sure what i would do without it.New 22ssbxp coming next week.
Smokey granite with metallic sorel accent
Tuscan dune interior
SPS with Yami 150
Ski tow bar
Dual battery
Adjustable height helm
I regret being to cheap to shell out 3k for the great looking blackout and 1k for in floor storage . Lol. However we're very excited and will be very happy with our new Benny. This forum has been very helpful, however, I didn't see this or even know a build sheet existed until after I ordered the boat.
Waiting for spring in MN .
Not to hijack this thread, quick question Spar-Toon: are you a Spartan too, or am I just reading too much into your username?![]()
Very clever name!1986 Grad from MSU - Go Green
I have a 22SSX w elliptical tubes and lifting strakes powered by a 115 Yamaha Vmax. Love it. Doesn't turn great but I didn't get it for sports. I can hit 39 once in awhile but she will hold 37.Not sure I have a regret, but now having this boat I know for sure what my next one will be. I will get a Benny Tritoon with the Windscreen for sure. Some nights get chilly here in Maine and I miss the windscreen of my bowrider on those chilly night rides. Makes a huge difference.
Have you had a chance to try your 22SSX out in fresh water to see what top speed is? I've seen 30 before on my 21SFX with ellipticals, on fresh water. Wondering if it worth my while to install stakes & foils on mine.I have a 22SSX w elliptical tubes and lifting strakes powered by a 115 Yamaha Vmax. Love it. Doesn't turn great but I didn't get it for sports. I can hit 39 once in awhile but she will hold 37.
Yes, several times. Solid 34 w same conditions; just me, fuel at half tank, no wind. Hitting 35 often but not holding.Have you had a chance to try your 22SSX out in fresh water to see what top speed is? I've seen 30 before on my 21SFX with ellipticals, on fresh water. Wondering if it worth my while to install stakes & foils on mine.
Thanks
