Unusual Deck Stain
WoodBH
My 2016 Bennington 21SX has developed a very strange, large stain on the stern deck forward of the motor and behind the rail. This portion of the boat is open to the weather. There is no rust dripping from above or anywhere on the boat. We’ve used cleaners, straight bleach, CLR plenty of elbow grease scrubbing it and even pressure washed it to no avail. It’s almost like it’s rusting from underneath? Bennington dealer/service is stumped. See photos below. Thoughts?
Pbakk
That is strange. I have used WD-40 on grease stains for carpet, but not sure how it would work on this type of flooring. If you use it, maybe try a very small test area first? Let us know how it progresses. Hopefully it is covered under warranty. Maybe the glue from the flooring is bleeding thru?
Alicedream
Warsaw, MO
You are not.the first one to have this issue. I have seen other posters on this site as well as others I go to. Talk with your dealer and see what they have to see but from the other posts I've seen on this issue it is probably a glue or flooring material problem.
BURRIS PROP
I have a similar stain on my aft by the motor.
Sacandaga Lake, NY
I had the same stain in the same place on my boat. Turns out it was from spilled gas. I only use ethanol free and since not available on the lake I carry it in 5 gallon containers. No matter what I did could not remove stain. Bugged me so much I eventually had the vinyl replaced. Have learned to be extra careful
Remediation
Use a super siphon.
Rick from Rocky Mount
Yes, there have definitely been other posts on this matter and I believe the floors were replaced under warranty. Check the other posts out.
Michiman
Okemos, MI
To be clear, it appears that you have carpeting rather than vinyl but I have similar staining on my vinyl. At first, I thought it was caused by a poor acid wash my dealer performed but over the past few years there have been a number of people that have posted with similar stains. Thankfully, my stains have faded since 2017 so they are not as noticeable because I haven't gotten anywhere with regard to a warranty claim.
Michiman
Okemos, MI
This is what my stains look like:
Pbakk
Boy - that staining looks bad and frustrating, especially on the newer vinyl flooring. I wonder if UV light is impacting it. Is it covered when not in use?
Michiman
Okemos, MI
Actually, the bow area is covered but not the stern. However, only the port side of the stern is affected so UV rays seem an unlikely culprit. As I previously indicated, I believe that the staining was the direct result of a poor acid wash, which the dealer is not disputing. However, I've seen some pictures from other owners that look like mine but had not been subjected to acid. Thankfully I have a 10 year warranty and the stains have mellowed in the past few seasons.
WoodBH
Just a note that the floor is vinyl, not carpet.
Michiman
Okemos, MI
Wow, for the life of me, that looks like carpet even after looking again. Guess I'm just used to the bamboo look that I have. That said, our stains look quite similar.
