ssc
Just a quick update. Running a 16p enertia. I always have my double Bim up. Only have 10 hours on the boat. I have been playing with the trim. Generally the air temp is above 100 and water around 80.
Holeshot is great as is midrange. So far the top end is 48.5 gps at approximately 6000 rpm. Slip is approximately 8%. I have had the same results with two people and half a tank of gas or 4 people with a full tank and coolers. Did I mention it gets hot here?
I tend to think that I am able to get the same results with the added weight due to getting used to the boat and its proclivities regarding trim and reading the water relative to the trim and how it reacts. I also think the motor is breaking in properly. I still think my lack of experience with toons is a factor, but i am trying to learn.
I tend to think as the motor continues to break in, and the heat abates and I "learn the boat" better, that it will exceed 50 mph with a light load. Update to continue.
Cheers, Steve
Cheers, Steve
